drpro
Everything posted by drpro
Hiding Lavs vs exposed for non-fiction. Opinions?
drpro replied to Dan Brockett's topic in Equipment
Some years ago as part of the interview, the producer wanted me hiding the lav on Dolly Parton while the camera rolled. Needless to say there was no problem hiding that little lav amongst the large mountains!! -
Mattias those clips are available for other vendors. The trade name is Mod-U-Lox. Here in the US, a pair cost less than 4usd. Misspelled the name Mattias, it is "Mod-U-Lok"
Do audio dealers check out consignment-sale gear?
drpro replied to Philip Perkins's topic in Equipment
I would suspect there is some truth to what you said Philip. Methinks everyone is busy and checking out used gear would be low on the list of must get done. Personally I have had better luck buying from someone on JWS. Just my take. David -
Version 3 of my quest for a Cantar Mini bag. This one weighs 2.4lbs/1.1kg. The fabric is Dyneema. Only weighs 5oz/145g per square yard. The space between the operator and the back of the Mini will house three Hydra sockets for Lectro SR receivers. Out of sight as the Cantar/Hydra controls each receiver. Antenna distro is my own version of pieces cobbled together. It has adjustable gain and a bandwidth covering A1 and B1. Hopefully this will help with desense of the receivers from transmitters outside of that range. If need be I have a couple of passband filters I can add. More photos to come.
Anybody have an idea where the microphone or elements are sourced. Curious how they sound to DPA or Cos-11.
KIss it is John. Maybe have wrapped the various mic bits and stands in holiday decorations, just to show you are a festive person!!
And the windows are not "anything proof"!!
Rent or borrow a C700s, one mic, done. Here is an example
RIP - Don Coufal, Boom Operator ... and so much more
drpro replied to Jeff Wexler's topic in Current
Condolences, Jeff and to his family. Cancer is one of the worst. -
More good advice from LD.
Thanks Jay for your thoughts. Much appreciated. This is why I wanted to ask, almost sounds to good. Tnx David
Has anyone used the Sonarworks software? Curious if it helps or hinders mixing. Sounds good on paper, just not sure. And yes they offer a free trial. Interested in real world users that have had it installed for longer than the trial. Tnx David
Never been a fan. To my ears due to the hyped mids and highs I found them very fatiguing to listen to for long periods.
Inovativ has introduced a new vertical cart. Might make a nice base for a sound cart. Looks to be somewhat modular and has the ability to add to. https://www.inovativ.com/shop/deploy/deploy-gen-iv-3/ One downside is the unloaded weight of 120lbs (55kg). Not a vendor, just an interested party.
I don't have one Constantin to try, but a thought. What happens if you add a length of XLR cable between the C preamp and the HM transmitter. I realize you wouldn't be using it with a cable, but curious if there is an RF issue. Also if you have a cable with a Neutrik EMC connector on the mic end try that. David
David's new vintage sound kit... What's up with that? ;-)
drpro replied to Jim Feeley's topic in Equipment
Peter I think you have the answer for those low balling producers. I will have to remember your quote and use it in the future. Thank you. -
True, 2kg, however that does include a PSC BDS along with the battery cup, USB power and the cables. So buy most any bag and add those items and the weight is probably in the 2kg range or better. The odd shape is really a problem. Definitely not a Nova, that is a really nice little package. Most of my work is on a small bag cart with occasional needs to wear the Cantar. I am too old for the run and gun shoots, regardless of how light the bag is!! Two hip replacements add to needing a cart. I have purchase a Hydra system to take advantage of the Cantar's ability to control all of the receiver functions, plus the ability to see the RF spectrum when scanning on that gorgeous bright screen. So I am in the process of designing another bag for the new bits. My sewing skills are not great, however I am going to try a fabric type bag which should be a bit lighter. I have purchased some Dyneema fabric which is very light and actually stronger than steel. I also have some RF blocking fabric and incorporate it into the bag, though I not sure it would make a difference. With the holidays here in the states soon upon us, hopefully I can find some time to work on it. David
You might check out RRC. 80-90 dollar range for the 98wh
I would imagine as SD owns Audio Limited, we will see a SD integrated mixer/recorder/wireless system. Seems like a nice idea for some. Kudos to Glen for bringing the Nova to fruition.
A review of Nova “OneUnit” and mrx214 wireless modules.
drpro replied to RadoStefanov's topic in Equipment
Love SQN, if they ever came out with a recorder along with their preamps.................. would be a sweet combo -
DIY custom light zaxcom nova OneUnit condor bag mod
drpro replied to RadoStefanov's topic in Do It Yourself
Dyneema CT-PSA, there are probably others that would work. -
Got a 3d printer. Try some TPU. MatterHackers has it in clear, I imagine other vendors do to.
True that Rado. I am starting to gather pieces for my version 3 bag for my Cantar Mini. I found some vendors that will sell small quantities of Dyneema fabric. Now that stuff is expensive, but really light. Like .5oz for a 36"x36" piece. A 36"x36" piece suitable for the bag only weighs 5oz. For some applications you don't even need to sew it. Seams for example. A super bonding tape along with an iron for a little heat transfer and you are done. Zippers still need to be stitched. -
One of my go to sources for foam and fabric has been Seattle Fabrics. They have several really nice thin foam pieces. Another source might be a camping supply store, use the foam from sleep mats. -
Definitely Minicircuits would be my go to. Just wanted to pass along the results of testing an inexpensive passband filter from China.
