Everything posted by Mungo
Shure teases bag/portable wireless systems. More info June 14?
Mungo replied to Jim Feeley's topic in Equipment
An engineer once told me that it takes a lot of magic to design even a two channel receiver for a slot. Some cameras provide less than 4 watts through the slot (which is by far very little power per channel) and heat is a severe concern. Some cameras rather add heat than dissipate. Possibly a reason why some manufacturers' leading receivers (Zaxcom, Lectro, even Deity) are not slot-in. -
Everytime I get the chance to record some classical music with an ORTF setup, I'm flabbergasted how good it sounds. Of course, it depends on the room. Be aware that any analogue wireless won't represent the transient sounds very well. Digital systems will do. And take care that it's a system that stays phase-locked when using two transmitters as a stereo pair. I know that Sennheiser 9000/6000 and Sony DWX will do, but don't know about the other common brands.
So it is a software bug? Which fw version are you working with? I guess we have the latest version and are working without issues (camera hop to XLR 1/2 and MI Shoe adaptor XLR-K3M to 3/4). Anyway, Sony announced an upgrade for May.
https://www.rfvenue.com/products/4-zone The only one (?) that really does what people like us need. Quite well built and quite versatile. Unfortunately rack size and only AC powered. There are people who have modified it to DC. In this forum there has been discussed this device a lot.
Yes, it works in mono. Unfortunately the preset lists don't match most of the time. SK500/2000 can do 50mW, SK100/300 only 30mW (in Europe). So cheapest combo is SK100 with EK1039 receivers. Pilot tone can be left on and operates as a better squelch.
I remember weak RF from a woman who was wearing a quilted thermal jacket. It took long before we found out that there was a layer of aluminium inside.
Sound equipment cameos [was: Aliens like pitch change]
Mungo replied to Jim Feeley's topic in General Discussion
Almost always seen in interrogation room scenes over here: Schoeps, Neumann KM or MHK40 on the table. No police dept would spend so much money on a simple interrogation recording system 😄 -
Curious about the distance between antenna and antenna
Mungo replied to gwak ki nam's topic in Equipment
At least one wavelength, as said by Shure. I've got a vintage Sennheiser system operating on VHF 37 MHz (bought just for fun on ebay years ago). The manual says the antennas have to be 8 meters apart 😄 -
In an ENG workflow like I've been doing quite often, it's absolutely useful. When there is no time and no location manager around to turn off the noise, it's as good as gold. Recently a camera person said that she wondered how I managed to boom so clear voices near a street with a lot of traffic ... just a little mystery but I admitted. So, for those SQN style productions where you mix directly it makes a lot of sense. I often had wished for something like this for years and knew it would be available some day. For fictional and properly recorded iso tracks it rather makes no sense, as stated by JonG.
Huh, difficult. Maybe it is possible to hide a supercardoid in plain sight? If there are bags n stuff lying around or even ambience microphones (e.g. for tv broadcast) mounted near him, no one would recognize just another (your) mike on a low stand.
Good idea, Peter. I only have an 833, but even configuring just six channels to the same status can be exhausting. It would also help designing clean standard setups for different tasks.
As the others here say: way better. But - it depends theoretically. I have measured around a lot, some time ago with the AVX system and found out that it's able to transmit 20Hz-20kHz without any audible artifacts and high dynamics. It tested a lot, also with "difficult" sounds. The only thing it can't transmit properly is Tone haha. It works rock solid over a short distance. So a very good basic principle, soundwise theoretically vastly superior to any analogue system. But Sennheiser made the mistake to never having developed a generation 2 AVX - there are neither professional transmitters (better inputs, variable input level, LCF) nor a plug on transmitter nor (bigger) pro receivers nor a handheld transmitter which can handle condenser capsules.
SD 633 - Using Wingman & a CL12 at the same time
Mungo replied to Donald Kauffman's topic in Equipment
Iron, that document says that there's no auto mixer control on the 633. Seems that SD has to update it: I remember having used Dugan - and the corresponding LED on the CL12 was on in each selected channel. Wingman gave more detailed visual feedback. This worked well. -
Did it lately. Works. Though I was running the latest firware, I faced some minor bugs. - once the meter views in Wingman were freezing - sometimes Wingman app would reboot itself all of a sudden - often 633 wouldn't boot properly, resulting me pushing menu button for 10 seconds ... I must say that I was running all devices (633, CL12, receivers, Lockit, Ipad) all on one v-mount battery which probably is not the best idea because it may draw too much power during the process of switching on. But no problems with recording or files. I'm used to using the CL12 together with an SD664 which works better in my opinion. -
Get some ground loop isolator for about 10 dollars. It is available for RCA or 1/8" plug und you will be fine. Second possibility is a dc/dc isolator which is a little more expensive and requires soldering.
You definetely need this bulky and heavy (and expensive) thing. Without it, there is only unbalanced output, and you mustn't run the S02D on 12 volts. In the DWA, there's a current converter to 7,2V. That's why there's no such cable on the market. It get's better with the DWR-S03 because it's available for Unislot also. Which you can easily adapt.
Inevitable: The gray "sock" on the boom.
True. That's where most semi pro filmmakers and fixed installations (used by no professionals like e.g. in houses of worship, by hobby music bands) operate today in GER. That band is free and fine. If they don't use old stuff 🙂
There are already a couple of other systems like this especially for the horse riding market, e.g. Ceecoach. I guess they are based on bluetooth technology. I once saw a camera crew specialized to only record / stream horseriding events, who themselves are experienced riders. They used such a system as Intercom. Range was from their "OB van" to cameras throughout the (crowded) riding arena. Cheep and good solution, was quite impressed. Intercom systems for sports referees (e.g. soccer) are also quite interesting - reliable products beyond our soundie's horizon.
Absolutely. I would suggest the lowest band, that's where I find most frequencies in this area. Btw. there are new rules in GER since april: You don't need a licence any more for your stuff, but you're only permitted to use it when you can declare that you make a living with sound. Non-pros must use other defined bands like 823 MHz, 863 MHz, 1,8 or 2,4 GHz.
As long as the audio connection to your other USB bank powered devices (wireless receivers / transmitters) is balanced, this will probably work. Otherwise you will most likely get some dc/dc transforming and ground related noise.
I don't need it for typical multichannel productions. But yes, there are jobs like: News, sports, run'n'gun. Broadcasted same day, sometimes even same moment (via 4G backpack on camera). Mostly one or few channels. Hard to say, as always. Interior probably equal to a worn out G2/G3, exterior 30 metres. It strongly depends if there is line of sight between TX and RX, which, for me, is given most of the time when it's mounted on camera and on the mixer. With people, animals, metal (e.g. vehicles) or glass windows between the units, the range will decrease dramatically. But enough for jobs mentioned above where range is not as important as freedom of movement and of course only off-air as a return. Greets!
Have been using it as a camera return feed for about a year and am quite convinced. No gain staging, directly out of camera's headphone (with DC blocking) into TX and RX directly connected to mixer's RTN input. In some environments there are immediate disturbances, probably by wifi and bluetooth. The worst connection that I had was in a hotel lobby at a red carpet event. I discovered that, most of the time, this can be solved by switching off and on again. Seems to sync on a new channel then.
Thx for the info, so not worth a try. I have used some type of HD 280 predecessor very few times. That was many years ago and I remember being quite disappointed.
Interesting, that looks like a solution! That's a very good tip! Does anyone know or even use Sennheiser HD 300 Pro? Are they suitable for our work or just another DJ phones?
