Everything posted by joinwooHK
Does this work on nomad Lite?
some ppl don;t want to clip on their pants , would it also make a ring to have a climbing buckle hang with the case?
I am using Lectro BLK 21 and Zaxcom BLK 21 . i know two blk are slightly different on the spectrum . How ould i improve the zaxcom gear range by adding a filter? adding after my RF multi output to Qrx? or it is just fine if it is QRX 100 ?
By few testing, i found improved result. I am using 1X qrx 100 and 1 X RX900 . 1 X 411 and 1 X 211 Now i route the RF Venue diversity fin two antenna output by T joint to RF multi input . And RF multi output each to the RX ,A antenna input, B input keeping kit antenna . As now , i found better result ,not big problem as far the test. May be i next should be getting the mic plexer
I just bought the a second hand RF multi , work with my 4 wirelss ( 2 Lectro , 2 Zxacom RX) with RF Venue antenna . I route one BNC from the RF multi 4 output to 1 antenna of 4 receiver A antenna input, the B input i keep using the original kit antenna . I found that it significant improve the range of Lectro , But Zaxcom RX doesn't seems have much effect, even sometimes goes little bit down compare to using 2 original kit antenna . Is that any reason of the designing principle of that? does the RF multi could not work on the Zxcom RX ,or i need to get mic pixler for doing this ? Thanks .... Jacky
Oh, it was success , very cool feature
Tried, but still not working that way...... set same gp same ID.....
Hi guys, I just recently change to Zaxcom wireless system , i got 2 TRX LA and QRX 100 (without IFB). , and TRX 900CL . I am trying to remote my TRX LA to record mode using rec run mode and IFB RX mode receiving signal from my TRX 900CL , i successfully sending TC to those TRX from TRX900CL. But i can 't press rec on TRX 900CL to Trigger the TRX record . Is it possible to do that ? or if it can , do i miss something? Jacky
I just bought TRX 900 CL, i found that the power connector is Switchcraft 761. However, i search on Trew, B& H ...........there is no Hirose to Switchcraft 761 power cable for me using the my BDS. and is there any other name of Switchcraft 761 , seems now very common ....
http://www.stanleytools.com/default.asp?TYPE=CATEGORY&CATEGORY=ZAG+ROLLING+WORK&PAGENUMBER=2 I just bought the stanely rolling case, used once , happy with them, got plastic shelf construct but aluminum surface board ,with drawers , not that heavy .seems solid . i used to use a makeup rolling case for that, but only half year it just broken, it is more tiny ,compact but most of them are cheap and thin wood board after i discover when i used that. just too fragile. but lights i am also still seeking a better design too....
WHt u should do is to use your equipment budget to. Hire a sound man, that all
Sorry if u same time is the cam operater (suppose documentary doesn't spilt dp and cam operator) and the sound man , forget all wht i said ..............
Sorry for my mixing up the headphone model. The AT mentioned is great headphone. the senator is right on that I though the Sanken CS3e or senns 8060 probably fis for you , i personal using CS2 , in quiet room it sound good, but not that great in noisy area. I though the stereo recording may be or may be not necessary in your case, Do u know where the final product project? TV , youtube , or cinema. Both have very different standard. If it is doing on Tv or you tube only , probably don't need that pretty amb recording . but if it is in cinema , even u may think of 5.1 amb recording. So i though where it goes finally definitely matter. I do most low budget drama or interview , and i save money to buy equipment one by one. So , i am not that luxury on buying equipment. And one man band , u may need to consider how convenient thing set up if u take about 10 or 15 min to set up 2 mic to do the thing..... it make not that suits.....some stereo mic may suits u more. docu may very fast moving in some shooting days...... u may need to got BDS power , NP 1 battery for ur recorder and the wireless receivers . And buy an pelican case for protecting ur equipment<they are expensive.......
and u will need a boom pole , even u are one man band , the run and gun style documentary , u must booming ..........and the boom sound always has Priority than lava mic in post ( given that both good and clean recording)
First Maxx seems won't be out that soon . if u need recorder urgent , i suggest nomad Lite. Since u will doing interview ( i think that is your most important part , got a good shortgun for that, Sanken CS2 or 3e , Senns 8060 , Schopes CMIT , extc would defintly do the job , i though the better shortgun for interview is much more important than recording ambience if your budget limited. ) if u are running single system , buy an good snake cable ( with 2 XLRs , Hp return ) , that ensure the camera record the right sound and convenience your work . Buy some lava accessories , under and over cover , fuzzy . sometimes , if the dir don;lt want lava mic visible ,u still need to do that lava hiding . U should got better headphone , Sony 7506, or senheiser HD 25 1-2 , the most common location usage headphone will give u good monitoring with comfort. although some complains HD 25 discomfort , i still love it. boundary mic probably not ur must buy itmes.....
Jack , Thanks for the advice , seems Camera Link and few ERX would slove my most problem , and i would leave the nomad as nomad Lite , and may upgrade later on . Since the back up recorder feature really attractive. I am using lectro and senns wireless systmen so probably not using Zaxnet that much.
Thanks every one device. I am thinking of if buying IFB 100 would definitely improve ,uch range that using Nomad internal IFB ? but really no idea how nomad IFB range since it is using wifi , different with comtek , or lectro . And jack, for the camera link , it is could be send the audio via Nomad IFB same as to ERX ? And but the nomad 10 involve USB mirroring , AES input , automixing....... does it involve change of the mother board? so need to send back to monthership..... thanks
I currently using Nomad lite as recorder and old comtek as IFB . Recently , i would like to upgrade my IFB . I noticed the ERX2 can been accepting audio from Zaxnet , so does it mean i caould upgrade my nomad to Nomad 10 or nomad 6( now no more available ) ? I can transmitting the IFB audio direct form my nomad to ERx2? It will save a lot from buying a IFB 100 /200 transmitter. is the range good for IFb , or i do need IFB 100 or 200 for IFB audio transferring? and what eaxctly the upgrade cost now from Nomad lite to next verson , since the product line change, the previous info can not applied. and for camera link , same ? can use nomad directly transferring audio feed? thanks a lot . Jacky
i just wonder u are part time Sound man and full time camera man , or u would do it at same time? if u do it at same time, meaning u doing both on same job, u probably won't get enough attention and hand to do the mix and look into the frame at same time.And BOOMing? if u doing part time sound man job , u may wait for the PSC new fieldmixer if u are not urgent , or got 442 ,dur to ur expandable in future.
What Plugins to complete my restoration bundles
joinwooHK replied to Tuhiva's topic in The Post Place
For my experience , Cedar > WNS > Izotope > Z noise Cedar always did the best sound and smooth , even u elimating some diag freq, actually it keep it naturally . WNs is the quickest one and effectively , i do it with same logic with Cedar , but however not smooth and natural sound as Cedar Izotope is most powerful software i guess , every actual ,precise adjustment can be made but for over all denoise , time consuming , But always save my life in some critical 1 take thing. Z noise good for deal with some constant noise , refrigerator , air con , HMi ....... But not gd for changing noise background. This is all my experience so far and i do denoise with WNs frist , if needed izotope .... (No having Cedar but hv little experienced and discuss with cedar user. -
Have you experience this_Sanken Cos-11D ssssssss.....
joinwooHK replied to hiro nakamura's topic in Equipment
there is possible that because SM and Um series need different wiring of the COS 11d , adding resistor as Lectro suggest make SM sound softer . So u may check rather this cause problems -
but any easy method to check this ? i tried put at distance in home inthe wood box.but it work well indeed
i got 2 sennheiser 3063 transmitter with around 7xx mhz , but i discover one easy interference with environment and apparently lower transmit distance compared with the other on field .But it is not very usual occurrence . But when i test at home that one seems work perfectly . So is it meaning the interference simply come with environment ? but i noticed that the RF signal is nearly full in Receiver 3041 U . but sometimes , during the shoot suddenly (interference noise come) , even without any distance change on the actor body , just sitting down ..... What kind of test or thing i can do with this ? Thanks your opinion
I am a fresh location recorderlist ,work @ Hong Kong. I usually work on my own for both recording and booming. I used to bring out 1650 pelican with me . But in fact it is not very convenient if thing need picking or resting my mixer bag on it ( not that safety and solid stand) . Therefore , i bought a cosmetic rolling case to build a mini cart. IT is tiny compare to most of ur cart due to in Hong Kong , the location almost tiny flat, office , crowd street , And i need to take all my equipment on my own from home ,taking bus or train to location ,Extremely mobility is needed and need to be fast.
Black Magic Cam ( ANY user?)
joinwooHK replied to joinwooHK's topic in Cameras... love them, hate them
Great .. ths for advices. Taipo , do u mean lacking supply?
