Everything posted by stefanosound
Hi Jack,can you put some pictures with the Maxx? thanks Stefano.
... I changed my cable after five years... is too difficult to refix tha kind of cable
...no news from Petrol or portabrace?
What do you think? http://www.filmtontechnik.de/603.html
compared with the lectro how they work?
...try to use one boom to put the tx higer is possible, This give you something more about the range,,,, putting one connector cable and higher antenna maybe can give you worste result...
Jack what do you think about the possibility to send the slate just on the tape/mono out? it could be helpful for giving istruction at the boom operator, or at the cameraman... thanks
With my Kata Harness I use the washing machine 30 dagre neutral soap....
first of all thanks for you help. I had sometimes the same problem in both cards may be is only my error.... I had sometimes the same problem on both cards. so it should not depend on the card Transcend 32 GB What happens if I start with mirror off and without stopping the session I move to continuos ? this may be my mistake? thank you very much .
it is in after power cycle : on
thanks for the advise. I use continuos mirror. is for this reason that _I do not understand. the zaxconvert saved me too much time....
first of all sorry for my English... Yesterday I recorded a conference, which was about three hours. after which I went in a theater to make a recording of a play, using a different card. Yesterday evening I checked the records and everything was perfect on the first card, in the second, I had to use the mirror, there was nothing in the audio file. Today I recorded a speaker, using the first card that yesterday was perfect. result, I had to use the mirror to retrieve the recording. this happened to me three times. This happens since I installed the 1.27 release nobody has got the same trouble?
yes Senator, I had a Shure 58 on my desk... so I made a mistake... Maybe I'm starting to be oldish...
...I had a job last week, where 10 db would have been much more useful ... Please Howy go on... thanks Stefano
...in add they are 60 mhz range...
For a low budget project, with a couple of D5, I was thinking at one Fostex AD-302 and a couple of Radio. Instead of G2 / 3 I saw the new SHURE UR1 and RU5 UR1 is 100mw. someone has tried them? thanks Stefano..
thanks guys
Can someone suggest a simple program to read the multi-track recordings. only to do a check at the end of the day ... thanks Stefano
Hi folks, how do you set in your maxx the mirror? on/off/continuos ? and why? thanks for your help...
which bag for maxx? I wish it could be opened at the bottom, in order to access the inputs. sometimes I work with 3/4 radios, sometimes with a stereo microphone, sometimes with a mono boom ... Stefano
I stored my setting in all the memory and in the card. When I try to recall ch 3 is out all the time. So I have to restart from factory setting.
Today still trouble on ch3 I have stereo mic on 3 and 4. Ch3 donot work. Factory reset every time I switc of. Seems like if the menory store do not work. My version is 1.11
I just update to version 1.11. I discovered that in record routing if I assain card 1 input 1, card 2 input 2, card 3 input 3, card 4 input 4, card 5 out 1 card 6 out 2, In playback I can hear only what was in input1 and 2, viceversa if I use defautl card 1/2 out 1/2 card 3/4/5/6 input 1/2/3/4 I can hear the full mix....
...my account is still waiting the autorization... can someone post me the file? thanks
help me please... Howy wher can I find the version 1.11, in zaxcom site i found only 1.07. I'm became crazy with my Maxx....
