Everything posted by Patrick Farrell
Yeah kind of a bummer you can't just remote the 610 when needed and instead would need a second unit. However, my experience was we rarely needed showlink control anyways. If we needed new frequencies, I'd just do it at the beginning of the day with the transmitters still at the cart. Only other use was to sleep/unsleep the transmitters for lunch or a long down time and we'd just have talent walk past the cart. But even with them close sometimes that could be troublesome and it wouldn't pick up the showlink. Separate issue I told the guys at Shure about but I'm trying to make the argument that a second 610 would only be useful in a very small use case.
Really nice work Wyatt. Half the space of the AD4Q. Only downside is you need the tablet/computer for easy settings management compared to the AD4Q.
Effect of human body on wireless microphones transmission
Patrick Farrell replied to henrimic's topic in Technical Reference
Their point of reference for radiated power increasing is 3 GHz. The effect will be much less pronounced at 1350 MHz. Also note they say shadowing increases with the frequency. So if you hide the pack on talent's back, you'll get a stronger signal with their back to you but relatively less when they face you which means greater fluctuations and a less stable signal. -
Right-angled XLR connector for Ambient poles?
Patrick Farrell replied to Johnny Karlsson's topic in Equipment
If you already have a side exit pole you could use a right angle adapter to turn the transmitter parallel to the pole. https://www.amazon.com/LyxPro-positioned-different-interfere-applications/dp/B073X2SDMJ Although I would make my own out of neutrik parts rather than trust that brand. -
Can anyone share details on what specific resistor value and configuration has worked for them in reducing the hiss? I’ve tried several values just in series and as an L pad but it just lowers the overall volume so that when I adjust the level back up it also brings up the hiss and the net noise floor remains the same.
Radio comm system that can tune in wireless mics
Patrick Farrell replied to Micah Henry's topic in Equipment
Some reality shows used to use the iCom https://www.icomamerica.com/en/products/amateur/receivers/r6/default.aspx It has a wideband FM mode that receives most analog transmissions including Lectro. Doesn't sound great but good enough for an IFB. Programs lots of recallable channels. -
Timecard Buddy Export Data Opinions
Patrick Farrell replied to NewEndian's topic in General Discussion
I don't know anyone that uses full social security numbers on their timecards. I'm all for being security conscious but I think you're making a mountain out of a molehill. -
Looking for someone with an accessible A10 Rack (ADX5D mod)
Patrick Farrell replied to Wyatt Tuzo's topic in Do It Yourself
Hey Wyatt, Just curious- are you saying they don't work together in the stock configuration? -
Here's a quote from the lectro HM manual: "An antenna is formed between the housing and the attached microphone, operating much like a dipole type. At UHF frequencies the length of the housing is similar to 1/4 wavelength of the operating frequency, so the antenna is surprisingly efficient, which helps extend the operating range and suppress noise and interference." That doesn't imply that wisycom operates the same way but it's possible they could. However, to say that using an xlr breaks the connection so you only have half a dipole shows that they don't understand how it actually works. There is still a ground connection through the xlr to the microphone which will load the opposing end of the antenna. In theory the length of the cable would affect the RF performance (just like the length of a mic would as well) but in practice you'll have RF trouble with your talent bodypack transmitters long before a plug-on transmitter mounted on a pole, provided the frequencies are clear.
Remote Roll a Sound Devices 644 from a Cooper 208D
Patrick Farrell replied to Daniel McIntosh's topic in Do It Yourself
Only way I can think of is to set the 664 to record when receiving timecode. Then you'd feed external TC through a relay switch which is controlled by the remote roll and thus whether or not the 664 is receiving that external TC. -
Pretty sure post still uses a 2 pop. https://en.wikipedia.org/wiki/2-pop
If I remember correctly, that menu is an output gain adjustment so "+4" means it is adding 4dB of gain to the output rather than providing a 4dBu reference level. The mixpre outputs are a nominal -10dBV so adding 4dB gets you to around -3.78dBu. You should make that setting about +12 which will get you pretty close to outputting 4dBu.
I'll provide a different perspective in that I doubt the lav was overloaded. You can test this by providing the same SPL to the mic and then adjust the transmitter gain down to see if the distortion goes away. My experience has been that "neverclip" in a transmitter is a bit misleading and gives a false sense of security. It's different from a recorder in that you don't have a fader to pull down that signal to fit into the 24 bit word. It's still going to clip.
The video guy should feed the monitors live from his switcher so there’s no delay needed. Then when they ask for playback he switches to the Qtake output. Also are you feeding audio to his cart and getting a return?
- 46 replies
- video lag
- sound sync
Help a real novice with their Sennheiser MKH50 P48
Patrick Farrell replied to JDub's topic in Current
At this point, I'd consider that the problem isn't with the MKH50 but elsewhere in the signal chain. I've heard that kind of noise before when it was a poor quality phantom power supply. Do you have an external phantom power box you could add in line? Or another mic you could try and see if the noise is still on the recording? You could also try cleaning the hot shoe contacts between the camera and accessory. -
Make sure the allen screws on the body of the mic are all snug. They make contact with a grounding strip that helps keep noise out. -
I had trouble with one of those dc-dc converter modules before where it worked fine with an alkaline battery but didn’t like an iPower. The best I could come up with was related to the load provided by the internal impedance of the battery. Inserting a 10 ohm resistor in line with the iPower made it work but was obviously wasteful in terms of power efficiency. Maybe experimenting with the load the converter sees could be helpful.
All BNC connectors manufactured to current specs will mate non-destructively. Sound Devices and all cameras I’ve bothered to check use 75 ohms for TC. But to reiterate what everyone else said, at the lengths we typically use it doesn’t matter.
Perfectly fine to use as a transmit antenna. You'll experience more range in the forward direction but less range when off axis. Just got to remember to point it where you want it.
The MixPre-3 does have an 1/8" stereo line level output. When first released, it was consumer line level but a later firmware update allowed gain adjustment for the output so you can bump it up to pro line level or even hotter.
If you really want to run the headphone signal analog, just take two line outs for the run and have a headphone amp near you. But in the case of the A&H, one of their ME personal monitoring systems would be more elegant. You'd still have to mix from an iPad though. Why are you wanting the mixer in the stagebox rather than a real mixer setup?
keyboard Sound Devices 970 / 270i / 260i Keyboard Compatible
Patrick Farrell replied to Ira Seigel's topic in Equipment
Most any generic USB wired keyboard should work just fine. I don't think bluetooth would work because there's no OS to manage the dongle. But an infrared wireless keyboard that comes with the dongle should work. -
I think the stuff in most headphone cables is called litz wire. Someone correct me if I'm wrong.
A 4 way split should be a 6 dB loss. I'd say "about 5 dB" is within the margin of error with the imprecise method of a receive antenna and transmitter some distance away.
