Ken Wilkinson
Everything posted by Ken Wilkinson
How about something like this? http://www.thetoolboxshop.com/0-777-15-15-core-retractable-electric-cable-3m-working-length-8140.html
Awesome video Ty, thank you!
Setting up a PT11 HD system for Surround Mixing
Ken Wilkinson replied to NCsoundNeil's topic in The Post Place
Go straight out of the Omni into the monitors. The Omni has a built in surround monitor controller that is fully calibratable . -
Alternative to BWF Timecoder
Ken Wilkinson replied to nickreich's topic in Recording Direct to Computer
Why not just create a Pro Tools template for each frame rate and have the timecode track pre-synced? -
Most obvious is the inability to use the Cut 1 or change capsules.
I built a 12v regulator for a BDS that I no longer use. Locking 761k plugs in and out. PM me if interested
Tired the Ktek and hated it. The blimp portion doesn't just slide on and off, you have to disassemble the entire thing. Look into the brand new Rode blimp. Looks really nice. lighter than original and cheaper too.
SD 633 Media I/O Errors w/ Delkin 700X CF Cards
Ken Wilkinson replied to bmfsnd's topic in Equipment
I did read it. The cards have known issues. I would stay away from that particular one.- 15 replies
- 633
- sound devices
(and 2 more)
With an annotation. Stick with the 1000x cards, no trouble whatsoever. Delkin Devices CF700X; UDMA6; 16 GB **See Note 1 Note 1: Sound Devices has worked directly with Delkin to identify an intermittent Media I/O issue with newer Delkin CF 500x and CF 700x cards. Delkin has confirmed that a recent change to these two cards is most likely responsible for the errors. Cards containing KZ in the serial number are susceptible to this issue and should not be used. Cards containing VB in the serial number will function correctly and are approved. Deklin CF 1000x and 1050x cards do not experience this issue and may continue to be used.- 15 replies
- 633
- sound devices
(and 2 more)
Those cards are no longer approved media. Try the 1000x cards.- 15 replies
- 633
- sound devices
(and 2 more)
+1
No drawers here but figured you guys might appreciate my Magliner water cooler bottle bag cart. Four folding shelves built in.
Beef up 8000 mic to fit invision lyer (tape) problem solved.
Ken Wilkinson replied to Glen Deakin's topic in Equipment
On the lyres, not the mic? Great Idea! -
Leaving mics in their shockmounts and zeppelins
Ken Wilkinson replied to Jesper Magnusson's topic in Equipment
I have an 816 I leave in a sennheiser blimp. I found it would work it's way out of the suspension on its own so I zip tied it in. Otherwise my short shotgun lives in a pelican in a softie, only use blimp when necessary.- 18 replies
- shockmount
- zeppelin
To power a BDS from an NP1 charger or other 12v source. Interested in selling this? I've been wanting to pick one up
I made it from scratch. Bread boarded it, made a prototype, then built the real one to fit into a small radio shack project box. I'll try to post a picture when I get home
correction: I used L712ra plugs on the voltage regulator to mate with the 761k BDS plugs common to BDS systems
I used switchcraft 761k locking coaxial plugs for use with my BDS plugs
I built a handy little voltage regulator for a few buck in the spring in a radio shack project box. Shouldn't be too difficult to build a 15volt version. 15v voltage regulator: http://www.ti.com/product/tl780-15 Simple circuit:
Jerry is the man! FAST turnaround
Try a hardware SPL meter. Radio Shacks will get the job done. For a typical sized "edit room" 76 - 79 db would be more appropriate.
Larry I have a 211 in block 26 that works fine as far as I can tell. It's on firmware 1.4. . I know the current firmware is 3.1. Worth getting this updated? Ps. Sorry to hijack this thread but while we are on the subject
photos?
Educated Soundies - There'e nothing like em (neither is he)
Ken Wilkinson replied to JackHenry's topic in General Discussion
at least he knows condenser mic's are more condensed. -
power options for SD 664 - no legacy battery needs
Ken Wilkinson replied to Larry Watts's topic in Equipment
Batteries for Broadcast's customer service is amazing. they called me back from out of the office in order to quickly respond to my problem ( which was by the way, operator error) and sent me a new charger no charge and allowed me too return the other unit after I received the new. In the end there was nothing wrong with the charger, I'm just a dope. their np1's and chargers have been great.
