Everything posted by Prahlad Strickland
The Arri issues an on screen warning, but the warning disappears and then re appears, and on and off all day. The audio always sync's perfectly, I hate seeing the warning. I also saw the warnings disappear with various clients based on firmware. Everything still sync's in post though.
b6 taped to their ears, hair, depending on the shot, shoulder I've had good results with.
Comparison of boom pole quick-release devices.
Prahlad Strickland replied to 13324's topic in Equipment
The orca one doesn't fit flush, the connection has movement. I'm gonna try one of these other ones. -
They using the sennheiser g3 for Tiger and Phil. Typical static and dropouts. Surprised on a bigger production like this. Especially live broadcast this was done. 😶
DPA slim cable getting stiff and brakes
Prahlad Strickland replied to Lauri Laagus's topic in Equipment
Dpa r a joke. I have 3 4063. At the connector all have failed multiple times. My cos11 while they don’t sound near as good. I’ve never had a connector end failure. Their denial is ridiculous. I have repair invoices from trew and Gotham to prove otherwise. They need to talk to countryman and Sanken about cable. Thinking about shrink wrap / glue retro fitting mine over to mogami lav wire. -
Anyone used the stingray junior and k-tek harness, or the k-tek waist harness in general? I plan to setup the mix pre 6, IFB200 and a QRX200 as a portable super lightweight setup with IFB200 as the master clock. Just wondering, looking at pictures, and without being able to try it here in Hawaii, curious how it goes being down low like that and walking around. Seems like it's ok for walking, but def seems restricting even for walking?
Anyone know where to get an old enough firmware to do a factory reset?
I formatted the card and updated to latest firmware so I don't have that.... so i'm thinking, if i brick it, I send it in, if I don't try I have to send it in anyway?, so I may as well revert to an old firmware, try... since my worst case is sending it in anyway?
I emailed Howy regarding the problem, basically it's the same as a few other users from different threads. I have the frequency matched to the QRX200, but no green light. I drop it one frequency notch and it goes green, momentarily before going red again. Factory reset fixed in both situations. Anyone know how to factory reset?, Hoping to get a response from Howy in time, if not if anyone knows how to do a factory reset on the TRXLA2.5 very much appreciate. I got as far as hitting the down arrow on the lock menu but there is no reset option in that factory menu.
Update on the upcoming Tentacle Sync-E
Prahlad Strickland replied to Mark Farag's topic in Equipment
That would be awesome!.... but not a waste of money, they are still the size of an iphone, they are very welcome by most camera crews who are used to both a timecode box.... + a scratch track receiver... I've tripled the money on my 6 ERX in rentals and have had zero complaints from any camera crew so far. They are very multi functioning. -
They are awesome. My LCD played up the other day. But seems ok now. Love the size and power of these batts. I'm using with Nomad. I have had an issue where I couldn't turn on the Nomad upon switching it on. Nothing would power up. I thought it was the battery budd 2. As it has an internal self resetting cap. Maybe it was the battery? I wonder if it also self resets? Takes like 30 seconds or so to reset. But other than that happening very rarely they have been great.
Zaxcom IFB + ERX does exactly this, and can also be used as dedicated IFB. It also re jams wirelessly through the day without having to re jam. -
Hi-q for a year. Awesome form factor. The mini ones r awesome and impressive wh for the size. Using the dual root audio charger and remote audio single as a backup.
The Arri Amira has 2 AES inputs both stereo. If I wire up the TA5 output on the QRX to a single XLR and switch to AES input on the amira, can I have 2 separate talent tx's going direct to the QRX and have it feed to the single input B (aes mode) on the Amira on ISO tracks? Or is this only possible if it's a stereo hop from a bag. My other option is to use the 2 analog ins, or 2 separate AES ins, or wire up a TA5 to 5 pin XLR. Be cool if I can go direct from 2 talent to the RX, and have both feed into the single AES input.
Nice, can't wait to see it, Will probably end up doing something similar.
Leave it for post. making a decision in the field on headphones with something like noise reduction doesn't make much sense. I can't think of any post guy that would appreciate it. Like Marc said, theres always a price to pay, unless your making pre and post noise reduction recordings, it's doing more harm than not.
The most effort ever put into a drive by.
Hoping the stick mic style has enough range. I'm guessing it will get 150 feet. But when used with sharkies I bet it will perform very similar to the antenna version. Or at least I hope. No antenna and no cabled xlr is so attractive. The 742 is to heavy for end of pole use. Anyone saying otherwise is probably sitting mixing vs swinging . I'm mostly bag work but always run wireless boom for a backup recording. I can't wait to do without the internal cable and weight.
Rechargeable battery recommendations for Zaxcom TRXLA3
Prahlad Strickland replied to sebdunn's topic in Equipment
The amazon nimh ones. I think they r 16$ for 8. Are great. Same performance as the eneloop pros. Price is perfect. Last a couple years if taken care of. But all of them including eneloop lose their mojo after a year in my experience -
Well then the plugon version is the clear choice for me. I guess increased range being the main reason, but failing to see any other reason why anyone would buy the lemo version? Oh. And why not an optiOnal antenna for the plug in tx? Cool as is. Optional antenna a good option.
I love the idea of the xlr version. But the lemo version is interesting in that it can be used with lav and boom. Be cool if they sold a boom clamp for the top of the boom to mount the lemo version. Anyone know of a simple way to mount the lemo version up too.
zaxcom 742 as stereo transmitter for zaxcom 200
Prahlad Strickland replied to Prahlad Strickland's topic in Equipment
I run the 742 at 25mw on my boom while carrying the bag all the time, almost always, doesn't seem to effect the range much of the talent TX running on the same block range. -
Something like this? https://www.amazon.com/Motorola-Business-CLS1110-1-Channel-Two-Way/dp/B0000AUFKI/ref=pd_rhf_dp_s_cp_4?_encoding=UTF8&pd_rd_i=B0000AUFKI&pd_rd_r=DXMV3ZSBWP1QGK487BAS&pd_rd_w=GZPez&pd_rd_wg=Cur1u&psc=1&refRID=DXMV3ZSBWP1QGK487BAS
