Elusive Sounds
New Brunswick, Canada
Freelance Audio Engineer
2,733 profile views
Anyone here have experience - better yet pictures - opening an audioroot or other smart battery? I have one bad cell in a pack and would like to play around with it without destroying it.
I think I remember reading about a person who repairs damaged COS11 mic heads. Can anyone point me in the right direction?
Im considering upgrading to a Mini Cmit from an 8060. Now that it has been on the market for a few year, I would love to hear more about user's eperiences using the mini cmit as primary mic for documentary stile work? How often do you find humidity to really be a problem? Do you have another mini cmit as backup to swap out or are you swapping out for sennheisers?
I've been trying to find a used MK8 for a while and came across the MK6. Anyone have any experience with the MK6 capsule? Seems like this would be a very versatile tool. Why did Schoeps discontinue these? https://www.bhphotovideo.com/c/product/515467-REG/Schoeps_MK_6_MK6_Multi_Pattern_Capsule_for.html PS if anyone is selling an MK6 or MK8, get at me! Thanks.
Im considering modding an HM to 5pin in order to use a stereo Pianissimo setup while only taking the pins of the mid mic for wireless. Does anyone have any pics to share of an HM or HMA before I go in for exploratory surgery?
I assume you dont mean AES50, but if you want AES50 to USB this works Klark Teknik DN9630
Which Orca bag is this?
FWIW Betso confirms the Bowties do block DC but they recommend turning off the DC supplies if possible...
Hi All, I have searched this website and have read both manuals and it is still unclear. While I wait for a response from Betso tech support, can anyone confirm if the Betso Bowties have DC voltage blocking circuitry built in? I want to know if I can use the Bowties with a Shure UA845 which supplies 12VDC on the BNC antenna inputs. I also have the older SNA600 which I know can be damaged when connected to a BNC jack that has a DC voltage across it's pins. Wondering if the same risk exists with the Betso Bowtie?
Could this be made to work on only a single SM transmitter on set if there were 4-5 Lectros on set, etc? I suppose you would have to connect to each BT device individually? If New Endian made this seamless in RM and the device was properly miniaturized it is a clever solution.
Best way to cut a hole in a Portabrace?
Elusive Sounds replied to Allen Rowand's topic in Do It Yourself
What is going on on those Sennheiser receivers? Modded with two output connectors? -
Tentacle Sync 'Track E' - New minirecorders with timecode
Elusive Sounds replied to pillepalle's topic in Equipment
I wonder if the headphone output will be adequate for feeding a transmitter such as an SMQV. -
Hi all, if like me you have a Tentacle Sync version 1 with a weak battery, then like me, you probably are having a terrible time finding any information on how to change it. Most retailers I contacted did not have stock on this part, let alone know that the part was available from Tentacle. Its an easy fix. The battery replacement kit which comes with a battery, new plastic housing, velcro hook tape, super glue and rubber color bands. I was able to open mine without causing damage to the original housing, so I just glued it back together on the side of the case opposite the screw. Here are some pictures:
Thank you both for the feedback. Seekai, depending on the complexity of the amplifier stage, it could be as simple as swapping out a few resistors or an op-amp to raise the gain of the amplifier at the output. Rick, you are correct, I was referring to the EK100 and I edited the OP. As for the output stage only outputting to left channel, I have considered that, and there could be a few solutions to this if a mod was to be attempted. Hard to say without having the PCB schematics of the EK100 and EK300 to compare. That's why I'm so keen on finding info on how this mod was attempted. If anyone has access to those schematics that would be awesome too!
