jozzafunk Posted March 22, 2013 Report Share Posted March 22, 2013 Was having the same issues with only hearing L channel on return - there is in fact a record channel option where it will record channel 1 to both channels and ignore channel 2. That obviously needs to be set correctly, was set a charming little trap by the last soundie as I wasn't aware of it until I started only hearing boom. Quote Link to comment Share on other sites More sharing options...
Philip Perkins Posted March 22, 2013 Report Share Posted March 22, 2013 Was having the same issues with only hearing L channel on return - there is in fact a record channel option where it will record channel 1 to both channels and ignore channel 2. That obviously needs to be set correctly, was set a charming little trap by the last soundie as I wasn't aware of it until I started only hearing boom. Unfortunately many video cameras have this "feature". phil p Quote Link to comment Share on other sites More sharing options...
Rich Reilly Posted June 27, 2013 Report Share Posted June 27, 2013 Working with 3 this Friday...2-3 person interview hardwiring from 442...xlr, hi rose..maybe isos Ask whether "monitor" add on is being used (as opposed to 1/8" in) Set input menu to Ch1. menu for return level if level button used for something else. missing anything? Quote Link to comment Share on other sites More sharing options...
studiomprd Posted June 27, 2013 Report Share Posted June 27, 2013 " missing anything? " maybe... Quote Link to comment Share on other sites More sharing options...
Rich Reilly Posted June 28, 2013 Report Share Posted June 28, 2013 That is so helpful, "senator". Quote Link to comment Share on other sites More sharing options...
Derek H Posted June 28, 2013 Report Share Posted June 28, 2013 My latest issue with this camera is broadband RF interference emanating from the HDSDI cable between the camera and an on-board LCD monitor mounted on the back of a shoulder rig. A scan on my QRX indicates almost full interference on all channels. The problem disappears as soon as you unplug the BNC at the camera end. The LCD being on or off makes no difference. The BNC cable is fairly thin and cheap looking. Hoping a beefier or double shielded BNC could help but we don't have one on hand unfortunately. Something to watch out for. I don't think this is a C300 specific problem. Could the type of coaxial cable make a difference? RG59 vs RG6 for example? Cue Senator: "maybe!" Quote Link to comment Share on other sites More sharing options...
studiomprd Posted June 28, 2013 Report Share Posted June 28, 2013 " That is so helpful, "senator". " (no need for quotes, and an upper case S, please...) come on, you are an experienced Pro. there are certainly more than just the few things you mention that will go into this gig... what did you expect for an answer ? Quote Link to comment Share on other sites More sharing options...
Rich Reilly Posted June 29, 2013 Report Share Posted June 29, 2013 I guess you prefer all caps: SENATOR Mike Michaels, c.a.s. I meant in terms of what would be unique to this camera in a straight to camera feed. But in general, I think there are times in fairly lengthy discussions about new gear to attempt a list of unique issues with the piece. Quote Link to comment Share on other sites More sharing options...
OmahaAudio Posted June 29, 2013 Report Share Posted June 29, 2013 what did you expect for an answer ? Something helpful? Quote Link to comment Share on other sites More sharing options...
studiomprd Posted July 1, 2013 Report Share Posted July 1, 2013 " Something helpful? " like: 'someone needs to monitor the camera's headphone jack'..? Quote Link to comment Share on other sites More sharing options...
BWilson Posted July 2, 2013 Report Share Posted July 2, 2013 Try using a different(better shielded) Cable. Quote Link to comment Share on other sites More sharing options...
studiomprd Posted July 2, 2013 Report Share Posted July 2, 2013 make certain all connections are correct Quote Link to comment Share on other sites More sharing options...
