Mark Vesterskov
Show me your bag
18 hours ago, joi b said:
My 633 setup - everything in the bag running on BDS and HI-Q juice
- Joi B  / Reykjavik
2 Sennheiser TX for "stereo" camera hops?
2 sennheiser g4 500 wireless into 2 and 3 and one G3 -100 feed for camera and director, and the other G3 for clients (muted when not rolling)
Edited by joi b
clarification
2 minutes ago, joi b said:
2 sennheiser g4 500 wireless into 2 and 3 and one feed for camera and director, and the other for clients (muted when not rolling)
cotcha 👍
- Joi B  / Reykjavik
Similar set-up for my 633. I wish the outer most pocket on the Stingray Jnr had opened ended zips (to the top of the pocket) so this type of RX could be clipped to the flap and settings adjusted easily on the units by letting said flap open. I could do it myself with scissors and snips but rather buy RX of a different form. As it is I clip the RX onto a rigid piece of plastic (6"x4") and slip this in and out of the pocket.
Inspired by Jonathan Lalouz, I decided to try out the Condor bags for a smaller setup. Here you can see the 633, with a Soundbags Dashboard, two SRs, and an AudioRoot distro. In the pocket to the left is my Comtek Tx, in the pocket to the right is a G3 that I’m temporarily using as a hop, and in the front pouch is my eSmart battery. There really isn’t a lot of room for anything else. I had to have all my cables custom made for low profile harnesses.
I really like this setup, and it does what it needs to for about 80-90% of my bag work. I have an V2 Dashboard, I understand that the V3’s are lighter than these. This setup puts the weight in one place as opposed to dispersing it throughout a larger bag, so it feels heavier when lifted by hand, but can easily be worn with just a strap without killing your shoulders/back. It is also so compact that it can fit into just about any kind of standard sized case.
As nice and small as this is, I like what @RadoStefanov is doing with the same bag for his Nova OneUnit.
Great review and great bag. I can not recommended enough. You can follow my mod post here in the DIY section.
Here is mine.
- 633
- 3pieces of SRc
- soundbag dashboard
- Rieger Antenna distro
- AudioRoot power distro
- NP1 batt in the back pocket
- 2pieces of sennheiser 2000transmitter for IEM
it’s  lightweight and awsome. I can use it with my RF Venue sharkFin antenna.
5 hours ago, IronFilm said:
You use UCR100 for IFBs? That curious, hadn't thought of that
UCR100 same as R1 and R1a, Just the knob is smaller than R1 and R1a,  so why not😌
9 hours ago, Soundio said:
Mixpre 6
MCR42s +MTB40s+MTP41s
EK6042+SK5212II L×2
UM450+UCR100×10(for CAM hops & IFB)
Hi, it's interesting to see Wisycom and Sennheiser side by side. I decide which system to go to. If you can compare the duel between them: if you compare battery life, RF quality, audio quality and ease of use?
Thank you very much.
No problem,I'll let you know if I did that.
Where is this output routes from on the 633? Is there a setting that lets you mute this when not rolling automatically or do you manually turn it down between takes?
If you haven't updated your 633 firmware in a while you'll need to do this, it was a relatively somewhat recent firmware update.
Not perfect but that’ll get me started on the nova.
New custom bag with magnets✔️
Nova with wings ✔️
Headphones to the right and boom to the left ✔️
3d printed Solid Battery sled ✔️
Stands up solid, 4 points attachements and weights under 6 pounds total ✔️
Nova with wings ✔️
Great setup.  I guess the million dollar question though is where do you intend on keeping all the "extras" in terms of batteries / transmitters etc etc?
I thought the point was that there ARE no extras - battery at the back, transmitters built in? Although I'm not sure what the Nova actually can do, I could be wrong. Otherwise - extras elsewhere
I think what the poster means with "extras" are those things that you need to have with you when working  ---  if you have another bag or a case that holds these things, like transmitters, lavs and mounting gags, boom mics, etc., then the bag that houses the Nova only needs the space for the recorder-mixer-receivers box and the battery. If you want to have all your stuff in one bag then of course a larger bag will be needed.
There is no battery in the Nova, and some people still rely on G3/whatever instead of Zaxnet for IFB transmission.
Get a small backpack if you need extra batteries and other stuff? I use a portabrace pouch on the belt.
Nova with wings ✔️
Interesting. What's the material (looks like fleece)? Why the wings?
Exactly.  I do a lot of run and gun documentaries and I love the idea of an all in one unit to simplify things and weight, however, when you are running around Any Town USA (or World), you need to have all the "extras" alongside you whether it be extra batteries / spare transmitters etc.  Right now I have a Pelican Backpack which has been fantastic to be able to keep it nearby in a support vehicle or worse case scenario throw it on my back and hoof around with it on.  I guess the advantage of this setup is that you wouldn't have to keep as many backup cables since there aren't any cables really to begin with!
