Barry OSullivan Posted July 23, 2007 Report Share Posted July 23, 2007 I've been trying to back up the internal hard drive from a Deva v to a Lacie external firewire hard drive, but the Deva keeps giving a firewire error message. I have found out that apparently the deva will not communicate with the latest firmware version in the lacie so it seems I need to downgrade the firmware. The problem is the only program I could get to do this is a PC program which I cannot get to work. It won't recognise the drive when connected to the USB port (on the PC) and windows XP keeps asking for a driver when I connect the Lacie hard drive via the firewire port (again on the PC), everything I can find out about lacie hard drives says that no driver is needed or available for these drives. I'm using a Lacie D2 Quadra external hard drive. Has anyone else come across this problem, or got any suggestions??? Quote Link to comment Share on other sites More sharing options...
FSBELLA Posted July 23, 2007 Report Share Posted July 23, 2007 Barry, it could be as simple as the following: after connecting the lacie hd, turn the deva off then turn back on. when ever anyone connects a external hard drive, you must turn the deva off & on in order for the deva to recognize the drive. also, did you format the drive? hope that helps, if not call or email coffeysound. Quote Link to comment Share on other sites More sharing options...
Barry OSullivan Posted July 23, 2007 Author Report Share Posted July 23, 2007 Hi FSBella, I have tried switching the machine on and off but it still won't recognise the drive, also, I've been unable to fromat it, again the deva won't recognise it as a mirror drive. Thanks though. I've been trying to back up the internal hard drive from a Deva v to a Lacie external firewire hard drive, but the Deva keeps giving a firewire error message. I have found out that apparently the deva will not communicate with the latest firmware version in the lacie so it seems I need to downgrade the firmware. The problem is the only program I could get to do this is a PC program which I cannot get to work. It won't recognise the drive when connected to the USB port (on the PC) and windows XP keeps asking for a driver when I connect the Lacie hard drive via the firewire port (again on the PC), everything I can find out about lacie hard drives says that no driver is needed or available for these drives. I'm using a Lacie D2 Quadra external hard drive. Has anyone else come across this problem, or got any suggestions??? Quote Link to comment Share on other sites More sharing options...
FSBELLA Posted July 23, 2007 Report Share Posted July 23, 2007 try formatting the lacie hd on a macintosh fat 32, windows dos. full formatt, rewrite ones and zeros. good luck Quote Link to comment Share on other sites More sharing options...
dfisk Posted July 25, 2007 Report Share Posted July 25, 2007 I had the same issue with my LaCie pocket drive (now discontinued and replaced with the rugged drive). It's a bus powered firewire drive. The first time I went to use it with the Deva, the Deva wouldn't see it. I formatted it with a Mac, and never had an issue since. I should also state that I only use this drive with the Deva, and nothing else. I have another bus powered firewire drive that I use for transferring things quickly. Quote Link to comment Share on other sites More sharing options...
Barry OSullivan Posted July 28, 2007 Author Report Share Posted July 28, 2007 I had the same issue with my LaCie pocket drive (now discontinued and replaced with the rugged drive). It's a bus powered firewire drive. The first time I went to use it with the Deva, the Deva wouldn't see it. I formatted it with a Mac, and never had an issue since. I should also state that I only use this drive with the Deva, and nothing else. I have another bus powered firewire drive that I use for transferring things quickly. Thanks Everybody but unfortunately none of those things worked. It does seem to be a Lacie firmware and Deva issue. Further investigation is happening. Quote Link to comment Share on other sites More sharing options...
