TheAudioSynthesist Posted May 11, 2012 Report Share Posted May 11, 2012 Hi everyone. I'm on a shoot in India and my fusion is acting up. It won't let me mirror to the mirror card nor is it letting me mount my ext LaCie anymore. It mounted fine the first two days then I switched cards and it stopped mounting. Replace the card with the first card and still nothing. Any ideas or tips? TIA Quote Link to comment Share on other sites More sharing options...
Joel Jameson Posted May 11, 2012 Report Share Posted May 11, 2012 Does the external LaCie power up via a laptop? If so, it could be a power supply issue internally. Have you put in a mirror card and just tried to format it through the menu? There were some tweaks in x.51 for new cards, what version's running on the Fusion? Quote Link to comment Share on other sites More sharing options...
soundtrane Posted May 12, 2012 Report Share Posted May 12, 2012 OT: hey man, where are you? give me a shout +91 9930903737 -vin (in Bombay as of now) Quote Link to comment Share on other sites More sharing options...
studiomprd Posted May 12, 2012 Report Share Posted May 12, 2012 " in Bombay as of now " I'm looking forward to stories, and pix... Quote Link to comment Share on other sites More sharing options...
TheAudioSynthesist Posted May 14, 2012 Author Report Share Posted May 14, 2012 I'm in Ahmadnagar right now. Internet is unreliable but I'll try uploading some pics right now. Mirror card not working. FireWire drive not mounting. Any thoughts? Vin: will try calling if I can't fix it. Thanks. Quote Link to comment Share on other sites More sharing options...
Mirror Posted May 14, 2012 Report Share Posted May 14, 2012 On my Deva V my firewire won't read as a being connected if I booted up the deva with the firewire already plugged in. I would have to boot up and then plug in my firewire. Quote Link to comment Share on other sites More sharing options...
soundtrane Posted May 14, 2012 Report Share Posted May 14, 2012 Vin: will try calling if I can't fix it. Thanks. sent you a PM... " in Bombay as of now " I'm looking forward to stories, and pix... Of what Senator? Quote Link to comment Share on other sites More sharing options...
studiomprd Posted May 14, 2012 Report Share Posted May 14, 2012 " I'm looking forward to stories, and pix... " ... from your mountain project-adventures Quote Link to comment Share on other sites More sharing options...
glenn Posted May 14, 2012 Report Share Posted May 14, 2012 Be sure you have the external drive power enabled and you have set the mirror destination as the firewire. Glenn Quote Link to comment Share on other sites More sharing options...
TheAudioSynthesist Posted May 17, 2012 Author Report Share Posted May 17, 2012 Be sure you have the external drive power enabled and you have set the mirror destination as the firewire. Glenn Of course Glenn. I've used your wonderful products in the past. The rental guy sent me a 5.8 and took he fusion back to Mumbai. Upon checking it out it had some internal error. I'm actually happier with the 5.8 as the internal hdd makes me feel better. This one is also mirroring no problem. Quote Link to comment Share on other sites More sharing options...
