Matt Geldof Posted June 18, 2012 Report Share Posted June 18, 2012 I am starting on a show that requires a light run and gun set up and production is asking that I provide a Comtek M 216 TX. I'll be feeding this from the tape out of my SD 302. Just wondering who's used the Sound Devices schematic to build either the mono tape or mic level output cable? http://www.sounddevices.com/notes/mixers/302/302-tech-note-adding-a-mono-mic-level-output/#more-35 Which is best for the M-216? Are there any other options out there that any of you have been using? Quote Link to comment Share on other sites More sharing options...
AudioSheik Posted June 19, 2012 Report Share Posted June 19, 2012 We made and sell this cable successfully for the m-216. I can send you the schematic we use. Quote Link to comment Share on other sites More sharing options...
Angelo Waldron Posted June 19, 2012 Report Share Posted June 19, 2012 I made the mono line level out cable for the 302. It worked, but when I was testing it I noticed that it also reduced the separation between the 2 XLR outputs... like the tape out is not isolated from the XLR outs. Needs a dedicated mono IMO. Try it and see. Quote Link to comment Share on other sites More sharing options...
Matt Geldof Posted June 19, 2012 Author Report Share Posted June 19, 2012 We made and sell this cable successfully for the m-216. I can send you the schematic we use. I'd appreciate if you could send that to me. Thank you. Quote Link to comment Share on other sites More sharing options...
Boomboom Posted June 19, 2012 Report Share Posted June 19, 2012 Did some ta3 302 out to 1/8" comtek in and been using that for years now. Quote Link to comment Share on other sites More sharing options...
André Boisvert Posted June 19, 2012 Report Share Posted June 19, 2012 In the same vein, has anyone made a box to switch between L/Mix/R using the tape out of a 302/442 to feed their Comtek? Quote Link to comment Share on other sites More sharing options...
jason porter Posted June 20, 2012 Report Share Posted June 20, 2012 I haven't, but I have been planning one. I am having a hard time finding a 3 position switch (on-on-on) that isn't gigantic. Quote Link to comment Share on other sites More sharing options...
André Boisvert Posted June 20, 2012 Report Share Posted June 20, 2012 That's perfect, Jim. Thanks. I see they don't make it anymore but there's one on Ebay with cables for $200. I had my mind set on a DIY solution, but I might just have to rethink that. Jason, I hope you'll post pictures if you make yours. Would love to see it. Quote Link to comment Share on other sites More sharing options...
John Blankenship Posted June 20, 2012 Report Share Posted June 20, 2012 It's a good idea to feed the M216 via the filtered cable Comtek recommends. It can make a difference. Quote Link to comment Share on other sites More sharing options...
guynoir Posted June 22, 2013 Report Share Posted June 22, 2013 I'm going to make some input cables for my 216, having somehow lost the ones that came with it :-/ The manual says "Tip-sleeve" for audio, is it unbalanced input, or is it weirdly balanced with the ring being ground??? Thanks! jg Quote Link to comment Share on other sites More sharing options...
Rick Reineke Posted June 23, 2013 Report Share Posted June 23, 2013 I have separate Tape out cables for 'Left only', 'Right only' and 'Summed'. (L+R mono). On the summed cable I put 10k ohm resistors to mitigate cross-talk. They didn't cost much since I built them myself. Quote Link to comment Share on other sites More sharing options...
studiomprd Posted June 24, 2013 Report Share Posted June 24, 2013 " Tip-sleeve" for audio, is it unbalanced input, or is it weirdly balanced with the ring being ground??? " the manual seems pretty clear... Quote Link to comment Share on other sites More sharing options...
