Tom Maloney Posted June 29, 2012 Report Share Posted June 29, 2012 Looking for a u shaped piece of metal that mounts on the front of a cart It looks to be about 4 inches long and would stick out from the rails about 2 inches. Saw it on one of the carts in the gallery, looks like a good way to protect gear from getting damaged from walls etc while being moved. any idea what was used or what they are called Thanks Tom Quote Link to comment Share on other sites More sharing options...
Philip Perkins Posted June 30, 2012 Report Share Posted June 30, 2012 You could make one of these pretty easy? phil p Quote Link to comment Share on other sites More sharing options...
ben lowry Posted June 30, 2012 Report Share Posted June 30, 2012 Sounds like you're describing rack handles, a flattened U-shape bar with tapped ends, made to span different numbers of rack units vertically. They're for pulling out installed gear, but can mount to rack rails for protecting gear. If you want a horizontal bar in front of the gear (like to protect Venue knobs), look for lacer bars. ben lowry Quote Link to comment Share on other sites More sharing options...
Michael Miramontes Posted June 30, 2012 Report Share Posted June 30, 2012 Can you post a link to the picture? Maybe I can give you tips on how to source the piece. Quote Link to comment Share on other sites More sharing options...
Tom Maloney Posted June 30, 2012 Author Report Share Posted June 30, 2012 I think Ben hit it for me Thanks Happy 4 th to all Tom Quote Link to comment Share on other sites More sharing options...
Daniel McIntosh Posted June 30, 2012 Report Share Posted June 30, 2012 Please post links to what you've found. These look quite elegant: http://www.handlesunlimited.com/ Quote Link to comment Share on other sites More sharing options...
