Valentine Posted June 3, 2020 Report Share Posted June 3, 2020 Actually I did not know about these; thanks! I wonder if there's some way a transmitter could be made where the plug is inside it, like behind the battery door. You insert the mic and the door closes over the whole thing with a sort of strain relief that catches the wire. No connector sticks out anywhere. Just a thought. Quote Link to comment Share on other sites More sharing options...
Adam Aslan Posted October 3, 2020 Report Share Posted October 3, 2020 On 6/2/2020 at 8:06 PM, John Blankenship said: If you haven't yet, see my post on these alternate Lemo style connectors: Thanks for sharing John. Would you and anyone else mind taking a photo of the tools you use to add a new or repair a LEMO connector? I just had talent sit on a connector that also had a microdot adaptor. Seems like those are more susceptible to damage. Quote Link to comment Share on other sites More sharing options...
Valentine Posted October 8, 2020 Report Share Posted October 8, 2020 I ordered 4 of these RED16 connectors. I'm going to start replacing my broken Lemos with these once they break. And they will break. Extremely fragile the stock ones I have. Absolutely can NOT use the "lav snake" to pull them down tight pants. The connector is guaranteed to rip right off. These do appear to be better than what I'm used to. Low profile but also a tightening collar that looks like I can just use needle nose pliers to tighten. Quote Link to comment Share on other sites More sharing options...
wbrincat Posted February 20, 2022 Report Share Posted February 20, 2022 hi guys, does anyone know the crimp size needed for the FVB? Quote Link to comment Share on other sites More sharing options...
The Documentary Sound Guy Posted August 2, 2023 Report Share Posted August 2, 2023 On 2/20/2022 at 1:24 AM, wbrincat said: hi guys, does anyone know the crimp size needed for the FVB? Bear in mind that the "correct" crimp size is also somewhat dependent on cable diameter. You may need to pad a small cable... Quote Link to comment Share on other sites More sharing options...
