jonathan chiles Posted July 19, 2012 Report Share Posted July 19, 2012 I have a Phonak neckloop with the original comtek plug removed. there are 3 cores (green, brown, white) and a shield. Anyone know how this could be terminated to work with a Sennheiser G3 receiver? Thanks in advance Quote Link to comment Share on other sites More sharing options...
Eric Toline Posted July 19, 2012 Report Share Posted July 19, 2012 I have a Phonak neckloop with the original comtek plug removed. there are 3 cores (green, brown, white) and a shield. Anyone know how this could be terminated to work with a Sennheiser G3 receiver? Thanks in advance Any chance part of the Comtek cable is still attaced to the plug so you can tell which core is attached to what terminal? The G3 system is unbalanced in & out. The tip is the audio out/positive and the sleeve is the ground. I suggest connecting the shield to the ground and trying each of the the other cores to the tip and see what works. Eric Quote Link to comment Share on other sites More sharing options...
studiomprd Posted July 19, 2012 Report Share Posted July 19, 2012 <cap> Quote Link to comment Share on other sites More sharing options...
jonathan chiles Posted July 20, 2012 Author Report Share Posted July 20, 2012 Ouch senator! Hoped you would let this one slide.. I did in fact contact Phonak about this last year and they were entirely unhelpful Eric thanks for the advice, the neckloop seems to work with shield and green soldered to sleeve and brown soldered to tip on the mini TRS. Strangely the signal level in the Phonak Phonito is quite low even with the G2 sysytem modulating nicely and I also have a persistant clicking coming through as well. Quote Link to comment Share on other sites More sharing options...
studiomprd Posted July 25, 2012 Report Share Posted July 25, 2012 " I did in fact contact Phonak " with so many of our "usual suspects" so helpful, it is also useful for us to learn which ones are not as helpful as they could be. Of course we need to understand that for many large companies, we may not be the target market, so they may not fully understand our needs, but I would expect better of Phonak. " signal level in the Phonak Phonito is quite low even with the G2 sysytem " now you are getting into the physics of how induction loop systems work, and the specific spec's of the components --which were not specifically designed to work with each other Quote Link to comment Share on other sites More sharing options...
