Phil Palmer Posted September 19, 2007 Report Share Posted September 19, 2007 Anyone know the 3M material that the Rycote stickies are made from? I'd love to buy it by the sheet... ~PWP Quote Link to comment Share on other sites More sharing options...
BVS Posted September 19, 2007 Report Share Posted September 19, 2007 I don't know the name of that product but I have been using this resin bonding tape for my lavaliers for many years with great success. http://scapana.thomasnet.com/item/all-categories/industrial/0485?&seo=110 I use it in conjunction with 3mm neoprene foam. I'm using DPA 4071s. Make a loop at the base of the capsule and enclose it in a sandwich of a small square of neoprene held closed with the resin tape. Add the fleece windshield to the capsule and attach some more tape to the exterior of the neoprene on one side only and secure to the inside of clothing.There is a rough side and smooth side to the neoprene.Use the rough side on the inside of the sandwich so the smooth side can move freely. This is my main rig for very fast attachment.It is impervious under clothing to most wind situations that you are likely to encounter. Don't try and remove the resin tape after each use but just add another layer on top. With each layer going on,so you get better isolation. The tape is very thin so when it does get a bit too thick make a new rig from scratch. Brian Quote Link to comment Share on other sites More sharing options...
Fernando Posted September 20, 2007 Report Share Posted September 20, 2007 I'd love to see a picture or a diagram of it, sounds great Also to have a close look at the materials Quote Link to comment Share on other sites More sharing options...
BVS Posted September 22, 2007 Report Share Posted September 22, 2007 I'm just about to go away but will post some photos soon. Brian Quote Link to comment Share on other sites More sharing options...
Fernando Posted September 22, 2007 Report Share Posted September 22, 2007 yes please, great! (Re: to message below): Thanks John Blankenship, I'll try to find it locally, looks good... Quote Link to comment Share on other sites More sharing options...
John Blankenship Posted September 23, 2007 Report Share Posted September 23, 2007 To mount lavs with Overcovers and Undercovers, I've used the Stickies, Top Stick (cut into smaller pieces), and these Stick-It Dots, which are 3/4" double-sided dots that hold better than the Rycote Stickies -- and cost less. http://www.filmtools.com/stitdo503di.html John Blankenship Quote Link to comment Share on other sites More sharing options...
ptalsky Posted September 24, 2007 Report Share Posted September 24, 2007 I'm still using a tape product called Hypafix. It's designed for medical use - to tape IV lines in place. It is designed to be put on skin, and holds really well. It's also very porous (sp?) and I can put it right over the mic head with no degradation in sound (I've used it with both B6's and COS-11's). It also works really well when you need to tack down the cable on the actor's skin - it is much more comfortable for them and I get fewer complaints. It runs about $11 for a 60 foot roll. Phil Quote Link to comment Share on other sites More sharing options...
John Steigerwald Posted September 24, 2007 Report Share Posted September 24, 2007 I'm still using a tape product called Hypafix. It's designed for medical use - to tape IV lines in place. It is designed to be put on skin, and holds really well. It's also very porous (sp?) and I can put it right over the mic head with no degradation in sound (I've used it with both B6's and COS-11's). It also works really well when you need to tack down the cable on the actor's skin - it is much more comfortable for them and I get fewer complaints. It runs about $11 for a 60 foot roll. Phil This sounds very similar to the 3M Transpore tape. I wonder if it's the same stuff from a different manufacturer? Quote Link to comment Share on other sites More sharing options...
ptalsky Posted September 24, 2007 Report Share Posted September 24, 2007 I just talked to my sister (a nurse) and she said no, that transpore is not the same as hypafix. Hypafix is a fabric-based adhesive and transpore is a plastic tape. While both have similar properties, she said that hypafix is the tape they use on things that are 'life and death' like IV lines, etc. Phil Quote Link to comment Share on other sites More sharing options...
John Steigerwald Posted September 24, 2007 Report Share Posted September 24, 2007 Good to know. I'll have to try some out. Quote Link to comment Share on other sites More sharing options...
