myke2241 Posted August 14, 2012 Report Share Posted August 14, 2012 Playing around with my new 788t i noticed the limiters were crossed out. I cant figure why they would be disable. anyone have some hints. Please do not say read the manual. i just spent the last hour searching how to fix this. Thanks Quote Link to comment Share on other sites More sharing options...
JonO Posted August 14, 2012 Report Share Posted August 14, 2012 You probably accidentally enabled the mix assist mode. -Jon Quote Link to comment Share on other sites More sharing options...
gpiegari Posted August 14, 2012 Report Share Posted August 14, 2012 Mix assist will not disable input limiters. High sample rate WILL (96khz). Setting the input for digital will also disable limiters. Glen Quote Link to comment Share on other sites More sharing options...
Mark LeBlanc Posted August 14, 2012 Report Share Posted August 14, 2012 Also make sure your not in 96k sample rate Quote Link to comment Share on other sites More sharing options...
JonO Posted August 14, 2012 Report Share Posted August 14, 2012 It doesn't disable them, but if I remember correctly, when you are in mix assist mode- you cannot turn them off or on because they are automatically on. -Jon Quote Link to comment Share on other sites More sharing options...
myke2241 Posted August 14, 2012 Author Report Share Posted August 14, 2012 im at 96k guys. i bet that is the reason why. Now the question comes. why does i cant i use limiters at 96k! it seems like a very odd limitation. Quote Link to comment Share on other sites More sharing options...
rofin Posted August 14, 2012 Report Share Posted August 14, 2012 Computation time and memory constraints I guess. Quote Link to comment Share on other sites More sharing options...
Jaymz Posted August 14, 2012 Report Share Posted August 14, 2012 im at 96k guys. i bet that is the reason why. Now the question comes. why does i cant i use limiters at 96k! it seems like a very odd limitation. It's because they are digitally controlled (still pre A/D). Not enough processing power to run them while recording at 96khz. I'd really love a 788t that had fixed analogue limiters like all other 7-series recorders so that there would be no such drawback. Quote Link to comment Share on other sites More sharing options...
myke2241 Posted August 14, 2012 Author Report Share Posted August 14, 2012 It's because they are digitally controlled (still pre A/D). Not enough processing power to run them while recording at 96khz. I'd really love a 788t that had fixed analogue limiters like all other 7-series recorders so that there would be no such drawback. i came from a 744t and i guess i took the limiters for granted. I also didnt know the limiters were digital in the 788t. i always thought the limiters were digitally controlled analogue limiters interesting.. Quote Link to comment Share on other sites More sharing options...
Jaymz Posted August 14, 2012 Report Share Posted August 14, 2012 i always thought the limiters were digitally controlled analogue limiters interesting.. You're correct, they're still analogue, the limiting happens pre-A/D. Just digitally controlled, which is what allows them to be adjustable. But I'd take the fixed/non-adjustable 744 limiters over that any day for them to work at 96khz. Quote Link to comment Share on other sites More sharing options...
Olle Sjostrom Posted August 14, 2012 Report Share Posted August 14, 2012 I don't like the limiters in 788 at all. In fact, I so do t like them to the degree that I still prefer the 744 in many cases.. Quote Link to comment Share on other sites More sharing options...
al mcguire Posted August 14, 2012 Report Share Posted August 14, 2012 I'm curious why you would need a limiter at 96k. Quote Link to comment Share on other sites More sharing options...
myke2241 Posted August 14, 2012 Author Report Share Posted August 14, 2012 I'm curious why you would need a limiter at 96k. recording fire arms. ammo is kinda pricey depending on what you are firing. it helps to have good limiters for the first few test shots. also during some BG recordings. you sometimes have surprises. they are just safeties but i honestly wanted to see how they preformed. Agreed, the 744t limiters sound better. SD pretty much added a compressor here. Quote Link to comment Share on other sites More sharing options...
Dan Ostroff Posted August 14, 2012 Report Share Posted August 14, 2012 recording fire arms. ammo is kinda pricey depending on what you are firing. it helps to have good limiters for the first few test shots. also during some BG recordings. you sometimes have surprises. they are just safeties but i honestly wanted to see how they preformed. Agreed, the 744t limiters sound better. SD pretty much added a compressor here. I believe the 788T limiter settings are set up as indicated below but just in case, here's a note from Sound Devices re: limiters: How do I make the 788T limiter sound like the limiter on the 702/702T/722/744T? The 702, 702T, 722, 744T, and 788T all incorporate analog limiters but the control and characteristics of the 788T limiters are slightly different. The 702, 702T, 722, and 744T have a fixed -4 dBFS threshold, 5 ms attack time, 20:1 ratio, and 200 ms release time. The 788T limiters have a variable threshold, release, and knee, and a fixed 2 ms attack time and an Infinite:1 ratio. To make the 788T Limiter sound similar to the 702/702T/722/744T Limiter, follow these steps. Set the Setup Menu option INPUT: LIMITER THRESHOLD to -4 dBFS. Set the Setup Menu option INPUT:LIMITER RECOVERY to 200 ms. Set the Setup Menu option INPUT: LIMITER KNEE to Hard-Knee with 20:1 ratio. Set the trim levels so that the normal level is about -20 and peaks around -12 dBFS. Taken from: http://www.sounddevices.com/notes/recorders/788t-limiters/ Quote Link to comment Share on other sites More sharing options...
myke2241 Posted August 14, 2012 Author Report Share Posted August 14, 2012 I believe the 788T limiter settings are set up as indicated below but just in case, here's a note from Sound Devices re: limiters: How do I make the 788T limiter sound like the limiter on the 702/702T/722/744T? The 702, 702T, 722, 744T, and 788T all incorporate analog limiters but the control and characteristics of the 788T limiters are slightly different. The 702, 702T, 722, and 744T have a fixed -4 dBFS threshold, 5 ms attack time, 20:1 ratio, and 200 ms release time. The 788T limiters have a variable threshold, release, and knee, and a fixed 2 ms attack time and an Infinite:1 ratio. To make the 788T Limiter sound similar to the 702/702T/722/744T Limiter, follow these steps. Set the Setup Menu option INPUT: LIMITER THRESHOLD to -4 dBFS. Set the Setup Menu option INPUT:LIMITER RECOVERY to 200 ms. Set the Setup Menu option INPUT: LIMITER KNEE to Hard-Knee with 20:1 ratio. Set the trim levels so that the normal level is about -20 and peaks around -12 dBFS. Taken from: http://www.sounddevi.../788t-limiters/ Thanks Dan. Quote Link to comment Share on other sites More sharing options...
JonG Posted August 17, 2012 Report Share Posted August 17, 2012 I agree with many of you here. The limiters on the 788 are no good, and if they are ever engaged on a take, that take is useless. I have disabled all limiters on mine because if for whatever reason I clip on a take, that take still sounds better than if they hit a limiter. Like many of you, would love the fixed limiters of the other SD products. Quote Link to comment Share on other sites More sharing options...
chriskellett Posted August 17, 2012 Report Share Posted August 17, 2012 I agree with many of you here. The limiters on the 788 are no good, and if they are ever engaged on a take, that take is useless. I have disabled all limiters on mine because if for whatever reason I clip on a take, that take still sounds better than if they hit a limiter. Like many of you, would love the fixed limiters of the other SD products. Well, I guess I have been making "useless" recordings for years with my 788T then. A bit strong, don't you think? They can be tuned to sound very nice with a little bit of tuning IMHO, If you are hitting them so hard to make it sound useless you might be doing it wrong. Quote Link to comment Share on other sites More sharing options...
pindrop Posted August 17, 2012 Report Share Posted August 17, 2012 Well, I guess I have been making "useless" recordings for years with my 788T then. I bit strong, don't you think? They can be tuned to sound very nice with a little bit of tuning IMHO, If you are hitting them so hard to make it sound useless you might be doing it wrong. Yes I've been making useless recordings every day as well Quote Link to comment Share on other sites More sharing options...
RPSharman Posted August 17, 2012 Report Share Posted August 17, 2012 I agree they're not very good. Useless is a bit strong. I run identical signals into my 788T and 744T, and where the 744T holds on nicely, the 788T does not. I disengage my limiters on the ISO tracks, relying on the Solice for the rare pre-fade slam. My choice on limiter for 788T is -3dB, soft 20:1, 200ms Robert Quote Link to comment Share on other sites More sharing options...
chris_bollard Posted August 18, 2012 Report Share Posted August 18, 2012 Maybe not great but better than the alternative. My setup is pretty much the same as yours, Robert, tho for some reason my input threshold is 3.5db. Quote Link to comment Share on other sites More sharing options...
