Scott Smith Posted August 16, 2012 Report Posted August 16, 2012 See: http://www.iphonelif...ember_146290664 No sure exactly what someone in production would use this for, but I found it interesting nonetheless. --S Quote
Philip Perkins Posted August 16, 2012 Report Posted August 16, 2012 I wonder if it would be possible to gang these units together somehow, for more inputs? I could see this being useful for remote control of a small PA, I guess. phil p Quote
Diego Sanchez Posted August 16, 2012 Report Posted August 16, 2012 You could route four different channels or isos, before the sender to directors or boom op headphones. Then they can decide their own mix depending on situation. Could work fine Quote
soundslikejustin Posted August 17, 2012 Report Posted August 17, 2012 You could route four different channels or isos, before the sender to directors or boom op headphones. Then they can decide their own mix depending on situation. Could work fine As long as you had one of these for each person who wanted to control their feed... It'd be like a Lectro Quadra, except mixing at the transmitter instead of the receiver. Quote
