commpost Posted August 18, 2012 Report Posted August 18, 2012 What kind of snake is best to go from the 788t to the Red camera? The Red One, for example, has 4 mini-XLR inputs for recording 4 tracks. A snake with 4 mini-XLRs on both ends would make sense, but so far I have not heard of such a snake. A standard ENG snake has full size XLRs on both ends, and is one supposed to use XLR to mini XLR adapters on both ends? That is not an ideal solution. I am thinking twice before picking up a standard ENG breakaway XLR snake. Any opinions welcome. thx Commpost
mpsanos Posted August 18, 2012 Report Posted August 18, 2012 I'd look at as feeding 2 cameras. So 2 breakaway snakes with pig tails to make the connection outta the 788 and into the Red. All the Red One users I've worked with already have their own XLR to TA3 's.
Eric Toline Posted August 18, 2012 Report Posted August 18, 2012 What kind of snake is best to go from the 788t to the Red camera? The Red One, for example, has 4 mini-XLR inputs for recording 4 tracks. A snake with 4 mini-XLRs on both ends would make sense, but so far I have not heard of such a snake. A standard ENG snake has full size XLRs on both ends, and is one supposed to use XLR to mini XLR adapters on both ends? That is not an ideal solution. I am thinking twice before picking up a standard ENG breakaway XLR snake. Any opinions welcome. thx Commpost Using an adapter of XLR-F to TA3-M allows you to use the main snake for other things besides the Red-1. It may not be ideal but it does work and works very well. The adapters are less expensive than a custom made snake that can only be used for one camera. Eric
Tom Visser Posted August 18, 2012 Report Posted August 18, 2012 Rent a Lectro D4 system? 4 channels and wireless that is as good as hard line, not just close.
commpost Posted August 18, 2012 Author Report Posted August 18, 2012 Thanks for the great ideas. I will look at the Lectro D4 but I doubt I can afford it. Commpost
Matt Bacon AMPS Posted August 18, 2012 Report Posted August 18, 2012 What kind of snake is best to go from the 788t to the Red camera? The Red One, for example, has 4 mini-XLR inputs for recording 4 tracks. A snake with 4 mini-XLRs on both ends would make sense, but so far I have not heard of such a snake. A standard ENG snake has full size XLRs on both ends, and is one supposed to use XLR to mini XLR adapters on both ends? That is not an ideal solution. I am thinking twice before picking up a standard ENG breakaway XLR snake. Any opinions welcome. thx Commpost I work with a wide variety of cameras so have opted for two mini XLR to a 12-pin Tajimi connector into which I plug in a standard loom/snake. At the other end use a standard set of ENG camera tails (Tajimi to XLR and return) with adapter cables depending on the camera. Less of financial investment overall. Plus if my primary set stop working for any reason I can simply swap out a back up!! Not so easy with custom cables.
John Blankenship Posted August 18, 2012 Report Posted August 18, 2012 Of course, this all begs the question (considering the widely-varying quality -- and lack thereof -- of Red's on-board audio), "How good of a camera link does one need for a scratch track?"
Matt Bacon AMPS Posted August 18, 2012 Report Posted August 18, 2012 Of course, this all begs the question (considering the widely-varying quality -- and lack thereof -- of Red's on-board audio), "How good of a camera link does one need for a scratch track?" Very true!
Steve Foy Posted August 19, 2012 Report Posted August 19, 2012 Of course, this all begs the question (considering the widely-varying quality -- and lack thereof -- of Red's on-board audio), "How good of a camera link does one need for a scratch track?" Took the words right out of my mouth.
studiomprd Posted August 28, 2012 Report Posted August 28, 2012 " but so far I have not heard of such a snake. " the "usual suspects" will make whatever you specify
RadoStefanov Posted August 28, 2012 Report Posted August 28, 2012 There is a red snake tail. I have one if you want to buy... Sent from my HD7 T9292 using Board Express
Philip Perkins Posted August 28, 2012 Report Posted August 28, 2012 There is a red snake tail. I have one if you want to buy... Sent from my HD7 T9292 using Board Express Yeah--I had PSC make me a 2 channel + return RED fan for my Beta snakes. Do you really want to send 4 chan to the camera? Montoring the return for 4 chan kind of sucks re selection. If the cam audio is just a ref then 2 chan will do fine, smaller, standard beta snake etc.. Better yet--make it easier on everyone and go wireless! phil p
greg sextro Posted August 28, 2012 Report Posted August 28, 2012 ...why bother, just send a scratch wirelessly. You have TC on both ends. Force them to use the tracks from your recorder. I fail to see the reason to send 4 hard lines.
Create an account
Register a new accountSign in
Sign In Now
