johnpaul215 Posted May 7, 2013 Report Share Posted May 7, 2013 Wohoo! Btw what petrol should i buy? Any word if a specific bag for maxx will be created? Sent from my iPhone using Tapatalk It looks like the Petrol 607 might work as is. That might depend on your wireless though. If you use four 411 RXs, then probably not. If you use two QRX100 or two SRb receivers, then it might work. I have a 607 for my 302 rig, and I think it would work. The only question might be how you do the XLR connections on the bottom and how the Maxx sits when it's all wired up. The problem with the original version of the 614 was the Zaxnet antenna, and that bag was not specific for the Nomad anyway, it was just a lightweight bag that could hold a Nomad or a 788 or something similar. I've put my Fusion in one. Quote Link to comment Share on other sites More sharing options...
glenn Posted May 7, 2013 Author Report Share Posted May 7, 2013 We will have PFL keys on the Nomad 8 fader attachment. The Nomad itself will stay the same. You will be able to control analog inputs 1-8 on the new panel so you will get PFL buttons there if you want it. Glenn Quote Link to comment Share on other sites More sharing options...
Cloud Wang Posted May 7, 2013 Report Share Posted May 7, 2013 We will have PFL keys on the Nomad 8 fader attachment. The Nomad itself will stay the same. You will be able to control analog inputs 1-8 on the new panel so you will get PFL buttons there if you want it. Glenn brilliant ! Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted May 7, 2013 Report Share Posted May 7, 2013 I think it would be better on both the extension and nomad tight next to the corresponding fader. brilliant ! Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted May 7, 2013 Report Share Posted May 7, 2013 I think it would be better on both the extension and nomad tight next to the corresponding fader. The first 6 faders on the new panel line up directly over the 6 faders on Nomad. Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted May 7, 2013 Report Share Posted May 7, 2013 Makes sense.... Quote Link to comment Share on other sites More sharing options...
mbois Posted May 7, 2013 Report Share Posted May 7, 2013 @Johnpaul How it sits up is mainly why i ask. Thanks for the info Thought i read somewhere about some brackets on the bottom that will lift it to accommodate xlrs. Or that right angle xlrs will do the trick. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted May 7, 2013 Report Share Posted May 7, 2013 @Johnpaul How it sits up is mainly why i ask. Thanks for the info Thought i read somewhere about some brackets on the bottom that will lift it to accommodate xlrs. Or that right angle xlrs will do the trick. Sent from my iPhone using Tapatalk I am going aes On the side... Quote Link to comment Share on other sites More sharing options...
johnpaul215 Posted May 7, 2013 Report Share Posted May 7, 2013 @Johnpaul How it sits up is mainly why i ask. Thanks for the info Thought i read somewhere about some brackets on the bottom that will lift it to accommodate xlrs. Or that right angle xlrs will do the trick. Sent from my iPhone using Tapatalk That's what I understand. I saw a demo unit months ago, but the bracket wasn't on it. Once it starts shipping we'll see. If the 607 doesn't work, I bet Petrol and Portabrace will make something. Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted May 7, 2013 Report Share Posted May 7, 2013 With the feet Maxx will be the same height as nomad Quote Link to comment Share on other sites More sharing options...
stefanosound Posted May 7, 2013 Report Share Posted May 7, 2013 From the Zaxcom site: There is also a Mono & Tape outputs. Does it mean that in the same TA5 there are one stereo plus one mono unbalanced output? thanks Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted May 7, 2013 Report Share Posted May 7, 2013 From the Zaxcom site: There is also a Mono & Tape outputs. Does it mean that in the same TA5 there are one stereo plus one mono unbalanced output? thanks Its two balanced outs on the same TA5 Quote Link to comment Share on other sites More sharing options...
stefanosound Posted May 8, 2013 Report Share Posted May 8, 2013 Thanks Jack, but Idon't understand, TA5 has five contact, assuming that one is ground the other four Tape out balance left & right, wher is the mono output? or are two differnt balance mono out? or you have to set one time mono and one time stereo tape out? grazie Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted May 8, 2013 Report Share Posted May 8, 2013 pin 1 is ground is for both tape and mono pin 2 is + for tape out pin 3 is - for tape out pin 4 is + for mono out pin 5 is - for mono out Both are independently routable - meaning that each one can have its own separate feed and you can adjust levels independently of each other. Quote Link to comment Share on other sites More sharing options...
stefanosound Posted May 8, 2013 Report Share Posted May 8, 2013 Thanks Jack. Quote Link to comment Share on other sites More sharing options...
Nick Campbell Posted June 5, 2013 Report Share Posted June 5, 2013 Any news on when this is shipping out? Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted June 5, 2013 Report Share Posted June 5, 2013 2-4 weeks. Did you pre order? Quote Link to comment Share on other sites More sharing options...
Nick Campbell Posted June 5, 2013 Report Share Posted June 5, 2013 Did not. Will there be a wait after pre-ordering? Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted June 5, 2013 Report Share Posted June 5, 2013 Did not. Will there be a wait after pre-ordering? Dealers have been taking pre-orders since Maxx has been announced - and I'm guessing dealers will be filling orders in priority of when they were ordered. So the sooner you order the sooner you get one. I have no idea how many units have been ordered and Zaxcom will be building machines as fast as they can - but it will take time to fill all the orders. Quote Link to comment Share on other sites More sharing options...
Nick Campbell Posted June 5, 2013 Report Share Posted June 5, 2013 If funds allow I might just move up to the Nomad Lite, but the Maxx is really appealing. Quote Link to comment Share on other sites More sharing options...
soundslikejustin Posted June 5, 2013 Report Share Posted June 5, 2013 Dealers have been taking pre-orders since Maxx has been announced - and I'm guessing dealers will be filling orders in priority of when they were ordered. So the sooner you order the sooner you get one. I have no idea how many units have been ordered and Zaxcom will be building machines as fast as they can - but it will take time to fill all the orders. Have they started a production run....or is this a "as-we-build-them" roll-out like Nomad was? Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted June 5, 2013 Report Share Posted June 5, 2013 Have they started a production run....or is this a "as-we-build-them" roll-out like Nomad was? Each unit is assembled by hand and tested and then shipped. Quote Link to comment Share on other sites More sharing options...
stefanosound Posted June 6, 2013 Report Share Posted June 6, 2013 I order the Maxx the 2th of May and a couple of day ago my Italian seller told me maybe in July... Could be nice to see the manual on line, at list... Quote Link to comment Share on other sites More sharing options...
RJBerto Posted June 6, 2013 Report Share Posted June 6, 2013 In this video @ 2:10, Glenn says "It has an extra tape buss and and what we call mono buss. These are actually real mix busses so there are actually 4 mix busses in the Maxx." I would love some clarification on that. Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted June 7, 2013 Report Share Posted June 7, 2013 In this video @ 2:10, Glenn says "It has an extra tape buss and and what we call mono buss. These are actually real mix busses so there are actually 4 mix busses in the Maxx." I would love some clarification on that. They can be used as mix busses. You can independently route your inputs, main mix buses and returns to both the tape and mono out. Quote Link to comment Share on other sites More sharing options...
