mr.incandenza Posted August 28, 2012 Report Share Posted August 28, 2012 anybody knows how to wire an ECM44 to a Sennheiser G3 3.5mm plug? PLEASEEEEEE Quote Link to comment Share on other sites More sharing options...
Eric Toline Posted August 28, 2012 Report Share Posted August 28, 2012 The positive wire goes to the tip and the ground goes to the sleeve. Eric Quote Link to comment Share on other sites More sharing options...
mr.incandenza Posted August 28, 2012 Author Report Share Posted August 28, 2012 thanx, but it's not working. i have 1 more (white) cable to place. Quote Link to comment Share on other sites More sharing options...
Eric Toline Posted August 28, 2012 Report Share Posted August 28, 2012 thanx, but it's not working. i have 1 more (white) cable to place. Ok connect the extra wire to the ground/sleeve and it should be fine. Quote Link to comment Share on other sites More sharing options...
Eric Toline Posted August 29, 2012 Report Share Posted August 29, 2012 Did connecting the extra wire to ground solve the problem for you? Eric Quote Link to comment Share on other sites More sharing options...
studiomprd Posted August 29, 2012 Report Share Posted August 29, 2012 " Did connecting the extra wire to ground solve the problem for you?" if not...(I know what is next...) Quote Link to comment Share on other sites More sharing options...
Eric Toline Posted August 29, 2012 Report Share Posted August 29, 2012 " Did connecting the extra wire to ground solve the problem for you?" if not...(I know what is next...) Really? Please enlighten us with your prognostication abilities. Eric Quote Link to comment Share on other sites More sharing options...
studiomprd Posted August 29, 2012 Report Share Posted August 29, 2012 " prognostication " I'm guessing he got it correct, but if not, he would have had the wrong lead on the tip Quote Link to comment Share on other sites More sharing options...
OmahaAudio Posted August 29, 2012 Report Share Posted August 29, 2012 " Did connecting the extra wire to ground solve the problem for you?" if not...(I know what is next...) " prognostication " I'm guessing he got it correct So which is it? Did you know or were you guessing? Quote Link to comment Share on other sites More sharing options...
sergiofucchi Posted October 2, 2012 Report Share Posted October 2, 2012 If You search on ebay You can find low price self made adaptor to di this. They have a condenser inside to block dc bias current. Quote Link to comment Share on other sites More sharing options...
