postaudio Posted September 2, 2012 Report Share Posted September 2, 2012 Hi, I've been using comtek pr 72-b (25 frequency) to send TC to a timecode slate. It was working fine. I got an old comtek (freq F) that I tried to use but whenever I have the Freq 25 (as TC Tx), I don't hear anything from the Freq F comtek except noise. It seemed to interfered a lot whenever I have the 2 units on at the same time. Any ideas? I know these are so old and I should get new ones but they are expensive... Any suggestions other than buying a new set? Thanks. Quote Link to comment Share on other sites More sharing options...
studiomprd Posted September 2, 2012 Report Share Posted September 2, 2012 " but whenever I have the Freq 25 (as TC Tx), I don't hear anything from the Freq F comtek except noise. " they need to be on the same frequency to work together... Quote Link to comment Share on other sites More sharing options...
Rick Reineke Posted September 2, 2012 Report Share Posted September 2, 2012 By all means, the trans. and recvr, would have to be on the same frequency. Do you know what LTC sounds like? ... noise.. to the average person. Quote Link to comment Share on other sites More sharing options...
postaudio Posted September 3, 2012 Author Report Share Posted September 3, 2012 Ok my bad I guess I am not clear about it. I have one of the comtek working with the time code slate. The second comtek I have connected to my mixer. I can hear everything fine until I turned on my time code slate comtek. As soon as I turned that on, I get noise. When I turned it off, it's back to normal. Both are on different frequency. F and 25. I don't really understand why. Let me know if that make sense. Thanks. Quote Link to comment Share on other sites More sharing options...
Marc Wielage Posted September 3, 2012 Report Share Posted September 3, 2012 With the 72MHz units, Channel F is at 75.500 MHz. From what I see, the only Channel 25 I can find is at 216.6125 MHz. There is a 5-25 channel at 78.600 MHz, and a 6-25 channel at 84.600 MHz. It's possible you have one of those, and maybe a harmonic is knocking out Channel F. I'd guess the only choice is to get a different crystal with a different frequency. Quote Link to comment Share on other sites More sharing options...
postaudio Posted September 3, 2012 Author Report Share Posted September 3, 2012 Thanks Marc! I'll try that and see if that works. Appreciate the input! Ben Quote Link to comment Share on other sites More sharing options...
