Ferdi Posted October 10, 2007 Report Share Posted October 10, 2007 I'll be using the Edirol R-09 for the first time as a back up recorder. The Edirol R-09 belongs to the producer and he wants to send timecode to the right channel and talent to left channel. Any tips, do and don'ts Thanks Fd Quote Link to comment Share on other sites More sharing options...
cmassey Posted October 10, 2007 Report Share Posted October 10, 2007 Kinda depends on what he wants to do with the files when all is over. If they are going to a transcription house, it would be best to check with them and see where they like the levels...one NYC house likes TC no lower than -6 and audio about the same! Is the producer going to label the files, make note of the file size, do the uploading, etc? In addition, since the levels can't be adjusted separately, you will have to either pad the TC down to mic or get your audio in from a line level source. Audio in is on a mini plug, so be sure it is seated properly, and not able to be bumped or moved while recording!!! cleve Quote Link to comment Share on other sites More sharing options...
Ferdi Posted October 10, 2007 Author Report Share Posted October 10, 2007 Cleve, I have never done a double system recording before. They do want it fot transcription, so I just just going my audio from one of the XLR out at line level off my mixer (wendt X5) and try to sent the tc via wirelles from the camera to the Edirol R-09. Would that work? Thanks, Fd Quote Link to comment Share on other sites More sharing options...
cmassey Posted October 10, 2007 Report Share Posted October 10, 2007 That should work just fine...but it is important that you or someone find out the tech specs from the transcription house...I have seen TC levels all over the place. TA in NYC likes it between -3 and -6 and audio peaks about the same level. But we used to send it with TC at -12 to -20 and they never said anything. Seems they were re-recording it in house, adding time to turning around the transcriptions. The producer may have the software and folks in-house to do the transcription....dunno??? It will take a Y cable with mini-stereo in. I may be stating the oh so obvious, and if so I apologize, but the mini plugs are a pain and you have to be careful with them and the R9! I like having the mini in be a right angle if you have it. For what it does, it is a very good little machine. Just make sure it is set for the lowest level of MP3 recording, so the file size does not get out of hand. And if the battery logo starts to blink, you don't have a lot of battery power left... Quote Link to comment Share on other sites More sharing options...
jason porter Posted October 10, 2007 Report Share Posted October 10, 2007 I put mine in a Petrol wireless pouch, along with a right-angle mini plug, it is well protected! Love the Petrol bags... -Jason Quote Link to comment Share on other sites More sharing options...
cmassey Posted October 11, 2007 Report Share Posted October 11, 2007 Jason...how do you get to the buttons with it in that case? I have a spot for mine in the mixer bag, PETROL and so far so good. I don't however roll it on much except interviews and maybe BU for music or a speech... cleve Quote Link to comment Share on other sites More sharing options...
jason porter Posted October 11, 2007 Report Share Posted October 11, 2007 I usually use mine as a backup when going RF to camera. It clips to the outside of my bag, with about 3-4 inches of slack on the cable so I can pull it out, flip the "hold" switch, hit record or stop, "hold" switch again then tuck it back away. I'll try to post a pic later today! -Jason Quote Link to comment Share on other sites More sharing options...
