BVS Posted October 19, 2007 Report Share Posted October 19, 2007 This is the resin type tape and the neoprene rubber. Quote Link to comment Share on other sites More sharing options...
BVS Posted October 19, 2007 Author Report Share Posted October 19, 2007 The neoprene is cut to just over a 1 inch size and a loop made in the base of the DPA 4071 secured by the resin tape. Quote Link to comment Share on other sites More sharing options...
curleysound Posted October 19, 2007 Report Share Posted October 19, 2007 Is that the "snot tape" that they use to put gels on frames? Interesting! Thanks, Tom Quote Link to comment Share on other sites More sharing options...
BVS Posted October 19, 2007 Author Report Share Posted October 19, 2007 Its then folded over on itself and a DPA windshield added.This is a mesh domed screen with the fluffy incorporated into it. No Tom its more like the sort of sticky they use to attach CDs to a magazine you'd buy in a bookshop. Quote Link to comment Share on other sites More sharing options...
curleysound Posted October 19, 2007 Report Share Posted October 19, 2007 What do you do with it after it's folded? Quote Link to comment Share on other sites More sharing options...
BVS Posted October 19, 2007 Author Report Share Posted October 19, 2007 The resin is stuck to just one side of the smooth neoprene.This rig works very well on all sorts of wardrobe and is fast to put on and take off.The cable microphonics are reduced by the neoprene and also gives you a solid attach point and base.The resin being very thin can be added to by putting on a fresh layer for each subsequent attachment. Quote Link to comment Share on other sites More sharing options...
BVS Posted October 19, 2007 Author Report Share Posted October 19, 2007 A closer shot of the resin tape.It is a Sellotape brand number 0485 made in England. This is wonderful for sticking metal to metal or plastic as it is very aggressive. To release a metal to metal grip just twist sideways. Quote Link to comment Share on other sites More sharing options...
Jeff Babb Posted October 20, 2007 Report Share Posted October 20, 2007 We used this stuff on Marc Pease Experience with Whit and Doug. I think it was called Joe's Adhesive Tape or something like that. We just called it Uncle Joe's snot. I think Fergie at Cinepartners in Wilmington, NC is stocking this now. A small hunk tucked inside the tie knot with the COS-11 kept it nice and secure. The fun part was putting needle nosed pliers up to the talents throat to extract the very sticky blob from the tie knot. Jeff Quote Link to comment Share on other sites More sharing options...
John Blankenship Posted October 20, 2007 Report Share Posted October 20, 2007 ...I think it was called Joe's Adhesive Tape or something like that... Close, It's "Joe's Sticky Stuff." http://www.filmtools.com/jostst3.html JB Quote Link to comment Share on other sites More sharing options...
ProSound Posted October 20, 2007 Report Share Posted October 20, 2007 Looks like I will buy some and try it out as another solution. Would this tape work well on skin too or would it not be a good idea Quote Link to comment Share on other sites More sharing options...
BVS Posted October 20, 2007 Author Report Share Posted October 20, 2007 This tape will stick to the skin and comes off ok.I'd probably go for topstick or transpore for 1st choice skin application.You can wrap it around capsules but you'll need to allow a little time to get it off.It sticks very aggressively to any metal or plastic which makes it great for place mic use.You only need a little of it but it is a stick once application.The neoprene rig with the DPA 4071 works because of this tape and its low profile and malleability.Its quiet!! Brian Quote Link to comment Share on other sites More sharing options...
Jan McL Posted June 3, 2010 Report Share Posted June 3, 2010 Nice rig, BVS. Will give it a shot one day soon! Quote Link to comment Share on other sites More sharing options...
soundtrane Posted June 3, 2010 Report Share Posted June 3, 2010 http://www.joeprops.com/ He's a great guy... -vin Quote Link to comment Share on other sites More sharing options...
Guest Ken Mantlo Posted June 3, 2010 Report Share Posted June 3, 2010 Close, It's "Joe's Sticky Stuff." http://www.filmtools.com/jostst3.html JB Also known as clear butyl (packaged in a 400' film can). Get some from your nearest on-set dresser, they usually have a shitload of it somewhere. That reminds me of one of my favorite grip jokes...."How does a grip count?"..."One, two, shitload." Quote Link to comment Share on other sites More sharing options...
berniebeaudry Posted June 8, 2010 Report Share Posted June 8, 2010 The resin is stuck to just one side of the smooth neoprene.This rig works very well on all sorts of wardrobe and is fast to put on and take off.The cable microphonics are reduced by the neoprene and also gives you a solid attach point and base.The resin being very thin can be added to by putting on a fresh layer for each subsequent attachment. Do you ever have trouble with the folded over neoprene popping open? Do you usually attach to the outer clothing, or does it go onto the undershirt if one is worn? Bernie Quote Link to comment Share on other sites More sharing options...
BVS Posted June 8, 2010 Author Report Share Posted June 8, 2010 Bernie, It takes a lot to get the neoprene apart without tearing it... I don't use it outside the clothes except on the inside wall of a jacket... I place it inside the shirt with the sticky stuff attaching to the shirt. The smooth side can then move against the skin. The thing that is good about the rig is you can drop the connector down the shirt and press the sticky to the shirt...and its all done in seconds....works in a lot of situations and you can add another layer of the sticky for the next rig. BVS Quote Link to comment Share on other sites More sharing options...
berniebeaudry Posted June 9, 2010 Report Share Posted June 9, 2010 Bernie, It takes a lot to get the neoprene apart without tearing it... I don't use it outside the clothes except on the inside wall of a jacket... I place it inside the shirt with the sticky stuff attaching to the shirt. The smooth side can then move against the skin. The thing that is good about the rig is you can drop the connector down the shirt and press the sticky to the shirt...and its all done in seconds....works in a lot of situations and you can add another layer of the sticky for the next rig. BVS Thanks! As soon as I get some of that tape I'm going to give it a try! My mics are Sonotrims so will have to modify it a bit perhaps. Best Bernie Quote Link to comment Share on other sites More sharing options...
Jan McL Posted August 27, 2010 Report Share Posted August 27, 2010 A word to the wise, Joe's did leave a mark on a piece of wardrobe when I endeavored to secure a stethoscope with it... -- Jan Quote Link to comment Share on other sites More sharing options...
Noah Timan Posted August 27, 2010 Report Share Posted August 27, 2010 I use and recommend 3M 924. Works well and so far, so good on not leaving marks. Quote Link to comment Share on other sites More sharing options...
Jan McL Posted August 27, 2010 Report Share Posted August 27, 2010 I use and recommend 3M 924. Works well and so far, so good on not leaving marks. Thanks, Noah, didn't know that. Found some @ Amazon and have added it to my expendables list -- Jan Quote Link to comment Share on other sites More sharing options...
Malcolm Davies Amps CAS Posted August 29, 2010 Report Share Posted August 29, 2010 Re Noah's info about the 3M 924. I did a search on the UK 3M site and the only 924 was a roll of sticky that needed a small hand applicator. Is this the same product and if so do you just cut a piece off with scissors or knife? Malcolm Davies A.m.p.s. Quote Link to comment Share on other sites More sharing options...
soundtrane Posted August 29, 2010 Report Share Posted August 29, 2010 <<The neoprene is cut to just over a 1 inch size and a loop made in the base of the DPA 4071 secured by the resin tape.>> BVS... was wondering what good would a loop do if it was completely stuck in... Just wondering... -vin Quote Link to comment Share on other sites More sharing options...
Malcolm Davies Amps CAS Posted August 31, 2010 Report Share Posted August 31, 2010 I looked on the Joe website and found that the "Snot" tape is made about 4 miles away from my home here in the UK so it looks as though I've served a packet on shipping from the US. Malcolm davies. A.m.p.s. Quote Link to comment Share on other sites More sharing options...
James Arnold Posted August 31, 2010 Report Share Posted August 31, 2010 I looked on the Joe website and found that the "Snot" tape is made about 4 miles away from my home here in the UK so it looks as though I've served a packet on shipping from the US. Malcolm davies. A.m.p.s. Would you mind sharing that location/company? I've bought it off TV and film retailers here in the UK for what struck me as hugely inflated prices... Quote Link to comment Share on other sites More sharing options...
BVS Posted September 19, 2010 Author Report Share Posted September 19, 2010 <<The neoprene is cut to just over a 1 inch size and a loop made in the base of the DPA 4071 secured by the resin tape.>> BVS... was wondering what good would a loop do if it was completely stuck in... Just wondering... -vin The idea of the loop Vin is to cut down the microphonic resonance in the cable...and thus less noise. A perfect example would be where you pinch the cable in your fingers at the base of the capsule.....it stops the microphonics instantly. I would love to hear if anyone has made any improvements to this rig. BVS Quote Link to comment Share on other sites More sharing options...
