michaeleaglehall Posted October 4, 2012 Report Share Posted October 4, 2012 First shoot with a Nomad and a Scarlet, they will be using the on board Scarlet sound rather than what I will be recording on the Nomad because it is for a 48hr film contest. Since the Scarlet inputs at mic level, about how much would y'all recommend padding down my nomad output? Any favorite settings or anything to worry about from you Nomad and/or Scarlet users? I figured I'd just use regular xlr to trs cables to input and then reduce my output by ~40db and see what that gets me, but if anyone has nailed this before it would be great to hear it. Thanks y'all. Quote Link to comment Share on other sites More sharing options...
Eric Toline Posted October 4, 2012 Report Share Posted October 4, 2012 A 40db reduction on the line out makes it mic level out. Should work perfectly. One of the Red cams, Epic or Scarlet (not sure which one) requires you to go into the menu and select balanced or unbalanced input. So whichever your feed is select accordingly. Eric Quote Link to comment Share on other sites More sharing options...
glenn Posted October 4, 2012 Report Share Posted October 4, 2012 Use the Nomad mic output level. It is -35dBu. It is set in the ENG setup menu. Any balanced output can be set to mic level. Glenn Quote Link to comment Share on other sites More sharing options...
