I have a Canare breakaway cable that I use to connect my SD 302 to camera. Recently, I've encountered a problem where one of the channels on the return will cut out. I had been able to fix it by jiggling the 1/8" return cable at the camera end, but that has stopped working. I unscrewed the housing and there doesn't appear to be any broken connections (though I'm no expert). There was also a broken connection at the 8-pin connector end of the camera end, but a friend soldered that back for me, which seemed to fix it.
Has anyone else had this problem? Were you able to fix it yourself? What should I be looking for? Would it be better to just send it to Canare for repair? Do they even do that?
Thanks for any help ya'll can give me!
p.s. I've included a few pics, though you can't really tell much from them.
post-7277-0-09130700-1353433972_thumb.jp
post-7277-0-93484100-1353433979_thumb.jp
post-7277-0-54479700-1353433985_thumb.jp
HI, and welcome,
" Has anyone else had this problem? Were you able to fix it yourself? What should I be looking for? Would it be better to just send it to Canare for repair? Do they even do that? "
yes, yes, bad connections, no because..., no
contact Eric.
