jonnyboom Posted January 4, 2013 Report Share Posted January 4, 2013 Hi all. I have seen in the manual for Lectrosonics SMDB that some mics can pick up RF from the TX being close to the mic. I am currently using the TXs on my booms utilising the Ambient UMPii power supplys. I can hear what can only be described as a strange "bubbling" noise during low level dialogue and inbetween speeches, although post production have not said anything as yet it is enough that i know it is there and need to find a cure. I am wondering if it is RF i am hearing through the mic so i have decided to try the capacitor tick as seen in the manual. Problem is i cant really understand the diagram. Can anyone tell me in lamens terms which legs to which pins, is it one or two capacitors. P.S the mics i am using are Schoeps CCM41s Hope this makes sense Regards to all Jonathan Seale AMPS/MIPS Quote Link to comment Share on other sites More sharing options...
rich Posted January 4, 2013 Report Share Posted January 4, 2013 try changing the gain setting up a few dB. when i first set up a 2020 for wireless boom, i had the gain set at 3, and could hear the compander fluttering. changing the gain to 4 made it sound great. Quote Link to comment Share on other sites More sharing options...
studiomprd Posted January 4, 2013 Report Share Posted January 4, 2013 " could hear the compander fluttering. " could not be! not on Lectro Digital Hybrid systems Quote Link to comment Share on other sites More sharing options...
Christian Spaeth Posted January 4, 2013 Report Share Posted January 4, 2013 does the bubble sound happen periodically at around 3 seconds? If so, then this is the battery telemetry. I posted about this some time ago. The last thing I heard from Lectro was that they were working on a firmware update to solve the problem but I'm not sure if it happened. That was some months ago. I'm sure Larry will tell us. Proper gain staging kind of solved the issue for me though. Quote Link to comment Share on other sites More sharing options...
Christian Spaeth Posted January 4, 2013 Report Share Posted January 4, 2013 " could hear the compander fluttering. " could not be! not on Lectro Digital Hybrid systems A rare chance to reprimand the Senator... I'll have to take it! Read Rich's post again. He was talking about a 2020 (Audio Limited) not Lectrosonics... Quote Link to comment Share on other sites More sharing options...
LarryF Posted January 4, 2013 Report Share Posted January 4, 2013 does the bubble sound happen periodically at around 3 seconds? If so, then this is the battery telemetry. I posted about this some time ago. The last thing I heard from Lectro was that they were working on a firmware update to solve the problem but I'm not sure if it happened. That was some months ago. I'm sure Larry will tell us. Proper gain staging kind of solved the issue for me though. The three second burble noise was due to the 3 second telemetry swing for the battery monitor. That has been indeed taken care of in an update. Service can tell you the status of any given unit as to whether the update is in the firmware. Best, Larry F Lectro Quote Link to comment Share on other sites More sharing options...
studiomprd Posted January 4, 2013 Report Share Posted January 4, 2013 " He was talking about a 2020 " Rich was, but it could not apply to the OP's problem with Lectro Digital Hybrid systems... ... and thanks for playing! Quote Link to comment Share on other sites More sharing options...
jonnyboom Posted January 5, 2013 Author Report Share Posted January 5, 2013 The "bubbling" noise is pretty much constant so i will try the capaitor route if someone can explain where i put it/them. Thanks for the replies Regards Jonathan Quote Link to comment Share on other sites More sharing options...
