solowiej Posted March 5, 2013 Report Share Posted March 5, 2013 I imagine this topic has come up before, but I have not been able to find any information on it. I'm considering swapping one of my lectro bodypack tx units for a HM tx. That way with the dual receiver, I can have one lav and one boom feeding straight to camera for a bare-bones in-camera mix. I know, not ideal. But here's the question: Can the HM also sport a lav mic? It will feed 5v phantom, will receive mic level from an analog xlr... I know the box is large and heavy for body-mounting, but this trick might give me more flexibility as both a boom tx and optional second lav. I'd like to know if there are any unforeseen reasons not to count on the HM working with a lav in a backup situation... Thanks for any insights! Quote Link to comment Share on other sites More sharing options...
studiomprd Posted March 5, 2013 Report Share Posted March 5, 2013 of course you could buy the Plug-on as an additional TX... or use the COS-11 with its Sanken XLR-powering module... or, of course, use the Lectro accessory... Quote Link to comment Share on other sites More sharing options...
LarryF Posted March 5, 2013 Report Share Posted March 5, 2013 I imagine this topic has come up before, but I have not been able to find any information on it. I'm considering swapping one of my lectro bodypack tx units for a HM tx. That way with the dual receiver, I can have one lav and one boom feeding straight to camera for a bare-bones in-camera mix. I know, not ideal. But here's the question: Can the HM also sport a lav mic? It will feed 5v phantom, will receive mic level from an analog xlr... I know the box is large and heavy for body-mounting, but this trick might give me more flexibility as both a boom tx and optional second lav. I'd like to know if there are any unforeseen reasons not to count on the HM working with a lav in a backup situation... Thanks for any insights! Here is an easy way of doing it. You can leave your lavaliere wired for a belt pack and use this adapter to convert to an HM plug on. http://www.lectrosonics.com/33-MCA5X/View-details.html You can also wire the lavaliere directly to an XLR but that is less flexible, though a little shorter. Best Regards, Larry Fisher Lectrosonics Quote Link to comment Share on other sites More sharing options...
ChrisH Posted March 5, 2013 Report Share Posted March 5, 2013 Much better solution would be to get a phantom power supply (denecke makes a good one) and an mc-35 cable to get into your existing body pack transmitter. That way you still have two body packs and the option to use one as a boom transmitter. Quote Link to comment Share on other sites More sharing options...
solowiej Posted March 6, 2013 Author Report Share Posted March 6, 2013 Here is an easy way of doing it. You can leave your lavaliere wired for a belt pack and use this adapter to convert to an HM plug on. http://www.lectrosonics.com/33-MCA5X/View-details.html You can also wire the lavaliere directly to an XLR but that is less flexible, though a little shorter. Best Regards, Larry Fisher Lectrosonics Thanks Larry! Good info. Nice that you're right here in NM... Quote Link to comment Share on other sites More sharing options...
solowiej Posted March 6, 2013 Author Report Share Posted March 6, 2013 Right, I've thought a lot about whether to go this route. The big issue is too much bulk and weight with a sloppy banded-together pair of devices on the end of my mic. Occasionally it's not on a boom but actually mounted on-camera (~shudder~) while the lav gets up close (OMB documentary work). So strapping both the power supply and SMV to the back of a mic would be a significant drag, relative to occasionally using the HM as a Lav tx. Much better solution would be to get a phantom power supply (denecke makes a good one) and an mc-35 cable to get into your existing body pack transmitter. That way you still have two body packs and the option to use one as a boom transmitter. Quote Link to comment Share on other sites More sharing options...
