FABER Posted March 13, 2013 Report Share Posted March 13, 2013 Hello, So I have a shoot tomorrow and I'll be using my trusty 552, they are using a Red Mysterium X. Is there any way to sync time code using just the Denecke SB-T? I've never worked with it before. Thanks! Quote Link to comment Share on other sites More sharing options...
stevegrider Posted March 13, 2013 Report Share Posted March 13, 2013 I think Mysterium X refers to the sensor inside the Red Epic camera. To feed it timecode from your SBT, you would need a BNC to 4 pin Lemo connector. This is just off the the top of my head, please verify. Quote Link to comment Share on other sites More sharing options...
edc133 Posted March 13, 2013 Report Share Posted March 13, 2013 The Red One can also have the MX sensor, I believe the TC input is still a 4 pin Lemo though. Quote Link to comment Share on other sites More sharing options...
atheisticmystic Posted March 13, 2013 Report Share Posted March 13, 2013 RTFM http://postproduction.pbworks.com/f/build_30_ops_guide_v30.6.0.pdf Page 75 Took me 120 seconds Bro-Heem. Best Quote Link to comment Share on other sites More sharing options...
FABER Posted March 13, 2013 Author Report Share Posted March 13, 2013 I think Mysterium X refers to the sensor inside the Red Epic camera. To feed it timecode from your SBT, you would need a BNC to 4 pin Lemo connector. This is just off the the top of my head, please verify. Right, but the 552 doesn't generate time code so i need to remain tethered to the SBT, so I guess my question is does the RED have internal time code I can sync with? Quote Link to comment Share on other sites More sharing options...
atheisticmystic Posted March 13, 2013 Report Share Posted March 13, 2013 ...does the RED have internal time code I can sync with? Still don't have 120 seconds? Quote Link to comment Share on other sites More sharing options...
stevegrider Posted March 13, 2013 Report Share Posted March 13, 2013 First set the SBT to free-run-time-of-day. You would then have to plug up the SBT to the RED, set the RED to external timecode and jam the timecode. Then plug the SBT to the 552. Be careful, RED timecode is known to drift. Rejam if the camera is ever turned off. Quote Link to comment Share on other sites More sharing options...
BAB414 Posted March 13, 2013 Report Share Posted March 13, 2013 First set the SBT to free-run-time-of-day. You would then have to plug up the SBT to the RED, set the RED to external timecode and jam the timecode. Then plug the SBT to the 552. Be careful, RED timecode is known to drift. Rejam if the camera is ever turned off. +1 Be wary of any Red power downs, frame rate changes, battery changes etc. Avoid using the camera as a master at all costs. I believe the Red One is a five pin lemo, while the other Red models are 4 pin. If I were you, I'd try to get my hands on a second sync box to sync to the first, which could live on the 552. That has worked for me in the past. Also, do not power down the sync box throughout the day unless you can manually set the TC, which I believe you can with the SB-T. Quote Link to comment Share on other sites More sharing options...
Martin Kittappa Posted March 13, 2013 Report Share Posted March 13, 2013 Some Red One Camera's also use Mysterium X sensors- The timecode input on these is 5 pin lemo. If it's Epic or Scarlet it will be 4 pin Lemo. Jam the SB-T from the 552 and feed the camera with the sync box and you should be good to go. Quote Link to comment Share on other sites More sharing options...
BAB414 Posted March 13, 2013 Report Share Posted March 13, 2013 The 552 has no generator and requires continuous jam. Quote Link to comment Share on other sites More sharing options...
Martin Kittappa Posted March 14, 2013 Report Share Posted March 14, 2013 Sorry my mistake- Looks like the Sync box will have to be the master time code as it will be the most stable. In that case use the sync box to feed the 552 and every time the Red powers down take the sync box and re-jam the camera- or even better if possible get a 2nd sync box one for the camera and one for the 552 Quote Link to comment Share on other sites More sharing options...
Marc Wielage Posted March 14, 2013 Report Share Posted March 14, 2013 So I have a shoot tomorrow and I'll be using my trusty 552, they are using a Red Mysterium X. Is there any way to sync time code using just the Denecke SB-T? I've never worked with it before. There is, but (as BAB14 points out) you still need a timecode source for the 552. Me personally, I think the 552 is good as a mixer and just "OK" as a backup sound recorder. I think either getting an additional timecode jam box or a full-fledged recorder is a better idea. I've never been happy with the sound quality on Red Ones, Epics, or Scarlets. They're very prone to overload, and I've seen cases where the camera operator either unplugs one of the sound channels or the levels get changed. To me, the camera audio track only works as a scratch track for editing -- but that's just my opinion. Note that the SB-T is just a jam box, so it's not presettable. For that, you'd need something like a GR-1 or GR-2 master clock, but you could limp by without one. All this stuff is widely available for rental in LA. Quote Link to comment Share on other sites More sharing options...
FABER Posted March 14, 2013 Author Report Share Posted March 14, 2013 First set the SBT to free-run-time-of-day. You would then have to plug up the SBT to the RED, set the RED to external timecode and jam the timecode. Then plug the SBT to the 552. Be careful, RED timecode is known to drift. Rejam if the camera is ever turned off. This is what I was hoping I could do! Thanks! Quote Link to comment Share on other sites More sharing options...
Philip Perkins Posted March 14, 2013 Report Share Posted March 14, 2013 BTW--the Red One TC connector is a 5 pin Lemo, not 4 pin. (4 pin is the Epic). The RED will drift off a jam almost immediately--we usually send it both ext sync and TC from an SBT which we leave hooked up to the camera all the time. philp Quote Link to comment Share on other sites More sharing options...
