LC21 Posted May 3, 2013 Report Share Posted May 3, 2013 Hey all, Does the W20 windscreen affect the sound substantially more than the B20 and double layered B20S? Any suggestion will be appreciated. Thanks Libero Quote Link to comment Share on other sites More sharing options...
studiomprd Posted May 3, 2013 Report Share Posted May 3, 2013 " Any suggestion will be appreciated. " visit your "usual suspect", and compare. sure, they are different, if you can notice... Quote Link to comment Share on other sites More sharing options...
John Blankenship Posted May 3, 2013 Report Share Posted May 3, 2013 I found the Schoeps windscreens colored the sound too much for my taste -- even the low end. I've been happier with a foam ball type for interiors and a modified Rycote Softie (removed the big rubber base and sewed it into just a nice furry ball) for more wind protection. Quote Link to comment Share on other sites More sharing options...
Derek H Posted May 3, 2013 Report Share Posted May 3, 2013 I like the B-5D. Quote Link to comment Share on other sites More sharing options...
LC21 Posted May 3, 2013 Author Report Share Posted May 3, 2013 visit your "usual suspect", and compare. sure, they are different, if you can notice... Hi Mike, I'm asking how huge the difference is and hoping that someone can share their views. Have worked a few times with a B20 but I have no access to neither of the two at the moment. You seem to have experience of both and I would be grateful if you could spend a few words about it. Thanks in advance, meantime thanks John and Derek. Libero Quote Link to comment Share on other sites More sharing options...
VM Posted May 4, 2013 Report Share Posted May 4, 2013 I use a W20 : it cuts a little bass frequencies but not too much. I do not like the B20, it seems to me that it cuts too much the low frequencies. For strong wind I use a babyball. It seems to be a personal point of view : some friends of mine do like the B20. Quote Link to comment Share on other sites More sharing options...
Derek H Posted May 6, 2013 Report Share Posted May 6, 2013 Note that the B5D provides a 'shell' of foam and leaves dead air between the capsule and the foam. I think it handles air movement much better than a regular foam. Still not good enough for exterior use. Quote Link to comment Share on other sites More sharing options...
Constantin Posted May 6, 2013 Report Share Posted May 6, 2013 I like the B-5D. +1 It sounds quite good. Better at handling wind than a regular foam. Like all things Schoeps, it's pricey Quote Link to comment Share on other sites More sharing options...
Masaki Hatsui Posted May 6, 2013 Report Share Posted May 6, 2013 The most transparent wind protection available nowadays is Cinela's Leonard. It's little bigger than Schoeps B5D, W20, pricey, but it protect very well and colours the sound the less. Quote Link to comment Share on other sites More sharing options...
demarsman Posted May 6, 2013 Report Share Posted May 6, 2013 Agree with John, foam indoor, ext modified rycote as well Sent from my iPad using Tapatalk HD Quote Link to comment Share on other sites More sharing options...
