fieldmixer Posted May 12, 2013 Report Share Posted May 12, 2013 Ok I'm worried now. I keep getting this error on boot. All settings get erased. Quote Link to comment Share on other sites More sharing options...
rich Posted May 12, 2013 Report Share Posted May 12, 2013 i assume you have tried re-formatting your primary card, and updating the software? Quote Link to comment Share on other sites More sharing options...
fieldmixer Posted May 12, 2013 Author Report Share Posted May 12, 2013 I have reformatted many times and tried multiple cards Same thing. I have no need to update software. 4.45 is as solid as can be in my experience and newer version offers no additional functionality for me. Quote Link to comment Share on other sites More sharing options...
Max Hirtenstein Posted May 12, 2013 Report Share Posted May 12, 2013 it's a problem with your saved settings. try reloading them. 5.16 is the latest by the way. Quote Link to comment Share on other sites More sharing options...
ccsnd Posted May 12, 2013 Report Share Posted May 12, 2013 did you format the card before you put it in the nomad? Looks a lot like you didn't. Quote Link to comment Share on other sites More sharing options...
rich Posted May 12, 2013 Report Share Posted May 12, 2013 I have reformatted many times and tries multiple cards. Same thing. I have no need to update software. if you re burn the software, it may replace or rewrite the DEVA.INI file that is bad or missing. Quote Link to comment Share on other sites More sharing options...
fieldmixer Posted May 12, 2013 Author Report Share Posted May 12, 2013 Actually, the mirror card I used had previously been a primary... But I'm Now using different cards. Same error. Quote Link to comment Share on other sites More sharing options...
Max Hirtenstein Posted May 12, 2013 Report Share Posted May 12, 2013 it's not a card problem. do a recall of your settings from the nomad or from an external cf card. Quote Link to comment Share on other sites More sharing options...
fieldmixer Posted May 12, 2013 Author Report Share Posted May 12, 2013 There were no settings to recall from. I attempted to store settings, power down, rebooted, still no settings to recall from. A Restore to factory defaults did it. Error now gone after boot. Thanks very much fellas. I love this board! Still have the jitters when a mystery error appears I guess... Quote Link to comment Share on other sites More sharing options...
fieldmixer Posted May 12, 2013 Author Report Share Posted May 12, 2013 The exact scenario preceding this error was: using two cards that had previously been primary. Formatted primary card in primary slot, erased Mirror card in mirror slot. First indication of issue was on battery change after battery ran dry during lunch. Still curious what exactly happened. If anyone know the engineering explination please share:) Quote Link to comment Share on other sites More sharing options...
deep owl Posted May 13, 2013 Report Share Posted May 13, 2013 "Restore to factory defaults did it" Yep, that is usually the first thing you want to do with troubleshooting NOMAD I think. It seems to make all sorts of problems go away. Glad you got it handled! Quote Link to comment Share on other sites More sharing options...
Mark Orusa Posted May 13, 2013 Report Share Posted May 13, 2013 Geez, if you'd followed the Zaxcom Nomad forum you'd probably have seen this sticky and avoided your scare: http://www.zaxcom.com/forum/showthread.php?16809-General-tips-when-changing-firmware-or-experiencing-bugs&p=20847&viewfull=1#post20847 Step #1: Restore to factory defaults. Mark O. Quote Link to comment Share on other sites More sharing options...
howy Posted May 13, 2013 Report Share Posted May 13, 2013 This error might have been caused by turning off the machine exactly at the time the current settings were being saved. The new software (5.16 - which I recommend every one upgrade to) has a moving dot on the display that reminds you when the settings are about to be saved so you can avoid turning off the machine just at the wrong moment. -howy Quote Link to comment Share on other sites More sharing options...
dominiquegreffard Posted May 13, 2013 Report Share Posted May 13, 2013 And once you restore to factory default (and fix the issue) is recalling from previous setting gonna make same issue reappear if you stay on same software version? Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted May 13, 2013 Report Share Posted May 13, 2013 And once you restore to factory default (and fix the issue) is recalling from previous setting gonna make same issue reappear if you stay on same software version?It depends. If the issue that is causing the error is within the saved parameters then yes it will reappear. Quote Link to comment Share on other sites More sharing options...
pindrop Posted May 13, 2013 Report Share Posted May 13, 2013 This error might have been caused by turning off the machine exactly at the time the current settings were being saved. The new software (5.16 - which I recommend every one upgrade to) has a moving dot on the display that reminds you when the settings are about to be saved so you can avoid turning off the machine just at the wrong moment. -howy Thanks Howy very useful, but do you know how can I stop myself thinking my Nomad is infested with tiny insects when I see one scuttling across - gets me for the first instant every time. I think it's got something to do with the size and speed it moves at? Quote Link to comment Share on other sites More sharing options...
Jeff Wexler Posted May 13, 2013 Report Share Posted May 13, 2013 I think maybe that comes from starring at it and wondering whether that is 6 legs or 8 that I see... Quote Link to comment Share on other sites More sharing options...
fieldmixer Posted May 13, 2013 Author Report Share Posted May 13, 2013 This error might have been caused by turning off the machine exactly at the time the current settings were being saved. The new software (5.16 - which I recommend every one upgrade to) has a moving dot on the display that reminds you when the settings are about to be saved so you can avoid turning off the machine just at the wrong moment. -howy Thanks for the precise answer! Quote Link to comment Share on other sites More sharing options...
