SMa Connects, No audio
ColinHart
Hey all,
I've got an SMa on set here - connecting to UCR-411a.
I'm getting levels on the transmitter (so the lav is fine) as well as full RF on the receiver, but no audio on receiver. I've checked all the settings on the receiver and can't find anything wrong. Also sent to a different receiver and had the same problem. Different freq, no change...
Any thoughts?
There is a "standby" mode on the SMa if you do not hold down the buttons for the power on sequence long enough. Try shutting it off and re-power holding down the buttons until after you see the LCD do a count from 1 - 3.
From the manual:
Power - On
The numerals count up from one and the boot sequence begins when the
count reaches three. “LECtro” is displayed as the boot sequence begins. If either button is release prior to the
screen reaching numeral three, the unit will enter the Standby Mode with no RF output.
Standby Mode
Pressing the AUDIO and FREQ buttons for about one second places the unit in
Standby Mode. In this mode the RF output is turned off so all setup adjustments can be made without interfering
with other systems operating in the same location. The screen displays “rf OFF” to remind the user that the unit is not transmitting.
Not in RF mute - getting full RF...
Tx is the problem, but can't figure out what it could be. Tx audio levels are reading fine, just not getting out. Was working fine 30 minutes previous - stopped while on break.
Possibly internal malfunction?
