jon_tatooles Posted May 24, 2013 Report Share Posted May 24, 2013 Firmware revision 3.0 is now available for the 788T and 788T-SSD. Link - http://www.sounddevices.com/download/788t-firmware/ New Support for 192 kHz sample rate. Up to four tracks (L thru , one media only. Scene, take, notes, false takes, circle and track name metadata is now linked between C-Linked 788Ts. Added L-ident tone mode, including TONE+LAMP shortcut to toggle the mode on or off. Added user-customizable CL-9 trim encoder adjustment. Affects trim gain and EQ Frequency. Option to decode MS into LR MIX only and leave ISO tracks as un-decoded MS. Added limiters for digital inputs (AES3 and AES42). Scene, take, notes, circle and track name metadata linked between two C-Linked 788Ts. Faster drive formatting. Added new Timecode mode, 'Free Run - Auto Output Mute'. This is the same as Free run mode, but mutes the Lemo timecode output when stopped. This can be used to roll external devices when Rec run timecode is not suitable. Change Default Ext Low Voltage Threshold changed from 10.0V to 11.3V. Fixes Output four, one sample delay. 4 GB file split bug. Various system improvements and optimizations. Quote Link to comment Share on other sites More sharing options...
rich Posted May 24, 2013 Report Share Posted May 24, 2013 thank you. now if only you hadn't released this the day before a really complicated job. and i like how the metadata linking between to 788's is so cool, you listed it twice. Quote Link to comment Share on other sites More sharing options...
Steve Joachim Posted May 24, 2013 Report Share Posted May 24, 2013 These are some of the highly anticipated updates and changes we had been hoping for. It really improves the usability of the CL-9 interface. Thanks guys! Quote Link to comment Share on other sites More sharing options...
jon_tatooles Posted May 24, 2013 Author Report Share Posted May 24, 2013 and i like how the metadata linking between to 788's is so cool, you listed it twice. We did that just to see if anyone is actually reading this stuff Quote Link to comment Share on other sites More sharing options...
VM Posted May 24, 2013 Report Share Posted May 24, 2013 Thanks. I will use some of these next week Quote Link to comment Share on other sites More sharing options...
rich Posted May 24, 2013 Report Share Posted May 24, 2013 We did that just to see if anyone is actually reading this stuff cool. what do i win? Quote Link to comment Share on other sites More sharing options...
myke2241 Posted May 24, 2013 Report Share Posted May 24, 2013 Awesomeness! Quote Link to comment Share on other sites More sharing options...
Cloud Wang Posted May 25, 2013 Report Share Posted May 25, 2013 Added new Timecode mode, 'Free Run - Auto Output Mute'. This is the same as Free run mode, but mutes the Lemo timecode output when stopped. This can be used to roll external devices when Rec run timecode is not suitable. all great stuff ! congrats ! Quote Link to comment Share on other sites More sharing options...
macruth Posted May 25, 2013 Report Share Posted May 25, 2013 Huge. Thanks! Quote Link to comment Share on other sites More sharing options...
Mark LeBlanc Posted May 25, 2013 Report Share Posted May 25, 2013 Jon Will the meta data sharing still work when a CL-WiFI is connected to the 1st 788? Quote Link to comment Share on other sites More sharing options...
d3sound Posted May 27, 2013 Report Share Posted May 27, 2013 thanks, jon Quote Link to comment Share on other sites More sharing options...
Marc Wielage Posted May 27, 2013 Report Share Posted May 27, 2013 Doh, I'm excited about the faster drive formatting! It takes forever just to format a 32GB CF card... Quote Link to comment Share on other sites More sharing options...
danelonsdale Posted May 29, 2013 Report Share Posted May 29, 2013 Digital limiters! Lovely. Quote Link to comment Share on other sites More sharing options...
pindrop Posted May 29, 2013 Report Share Posted May 29, 2013 Digital limiters! Lovely. Agreed, a first I believe well done SD. Quote Link to comment Share on other sites More sharing options...
Marc Wielage Posted June 4, 2013 Report Share Posted June 4, 2013 On the other hand... I hate when this happens a few hours before an early-morning shoot: Because I love to live on the edge, I went through all the menus and did a few test recordings under 3.00, and the machine "seems" to work, and I made it through an entire job today (2 tracks only) with no issues. I'm going to try the firmware update again and see if it sticks this time. Usually, I have much better luck with this stuff... Quote Link to comment Share on other sites More sharing options...
pkautzsch Posted June 4, 2013 Report Share Posted June 4, 2013 I had to change over from a 2.19 rental device that had to go back, and had a V3 788T the last two days. Worked fine on the job, except for not loading *all* settings from that file from the previous unit on the CF. I had to manually set it to write to INHDD and CF, standard setting seems to be EXHDD only. So far, no "programming errors". Quote Link to comment Share on other sites More sharing options...
VM Posted June 4, 2013 Report Share Posted June 4, 2013 I have worked one week with the 3.00 on one 788 and 2.19 on the other. No I haven't had any problems with the 3.00, I am going to update the second unit. Quote Link to comment Share on other sites More sharing options...
Marc Wielage Posted June 5, 2013 Report Share Posted June 5, 2013 I had to change over from a 2.19 rental device that had to go back, and had a V3 788T the last two days. Worked fine on the job, except for not loading *all* settings from that file from the previous unit on the CF. I had to manually set it to write to INHDD and CF, standard setting seems to be EXHDD only. I caught that, too, but only because I'm anal enough that I meticulously went through all 106 menus to check every one of them. You'd think it would produce a warning message when it didn't connect to an EXHDD, yet it was set to record to one... Attempting to update the firmware yet again. Quote Link to comment Share on other sites More sharing options...
VM Posted June 5, 2013 Report Share Posted June 5, 2013 106 menus You can edit shortcuts in the menu by pressing a few seconds "play" when you are in the menu. It permits to access quickly to the important menus. Quote Link to comment Share on other sites More sharing options...
Marc Wielage Posted June 6, 2013 Report Share Posted June 6, 2013 In an update situation, I'm not about to let one menu item default to a weird setting without looking at it first. Second update failed, now trying for a third. Also talked to SD support in email, no solution so far. Quote Link to comment Share on other sites More sharing options...
Marc Wielage Posted June 10, 2013 Report Share Posted June 10, 2013 And my thanks to Scott Farr, who sent me a message advising me to reformat the hard drive from scratch and then installing the new firmware. That did the trick: It would be nice if Sound Devices might include this little tidbit in the ReadMe file for the upgrade. Why the machine is "happier" doing the upgrade on an empty hard drive, I have no idea. BTW, it took less than 5 seconds to reformat the drive, which was the fastest I've ever seen. Kudos to SD for pulling that off. Quote Link to comment Share on other sites More sharing options...
Gabe Stewart Posted June 10, 2013 Report Share Posted June 10, 2013 Alerted sound devices support this morning to a little bug I found in this firmware update. They were able to recreate it on their machine and are now working on a patch. Switching a single input's left or right routing between post and prefade changes the setting for all inputs. Quote Link to comment Share on other sites More sharing options...
VASI Posted June 10, 2013 Report Share Posted June 10, 2013 With CL-8? Quote Link to comment Share on other sites More sharing options...
Gabe Stewart Posted June 10, 2013 Report Share Posted June 10, 2013 Yep with CL-8 attached Quote Link to comment Share on other sites More sharing options...
rich Posted June 10, 2013 Report Share Posted June 10, 2013 I thought that was always the case. Tracks could only have inputs routed to them all prefade or all postfade. Though I may be confusing that with the aux channels. But would think the same applies. Quote Link to comment Share on other sites More sharing options...
