daniel Posted May 30, 2013 Report Share Posted May 30, 2013 I've been asking and reading around for a conclusive answer on this but i have had conflicting advice and opinions from respectable sources (i have also done a jwsg search). I've also read that even if kit is not damaged by phantom power the audio can be affected and so can power usage. The tascam dr - 680 switches phantom power on I/Ps in pairs. What can and can not be plugged into phantom power I/Ps (without damage to kit or other undesirable effects)? What is the best (cleanest, lightest, lightest) way to resolve the issue of switched pairs? A external phantom power box or phantom power filter or isolation transformer. Many thanks in advance for all replies. kind regards, dan. Quote Link to comment Share on other sites More sharing options...
soundslikejustin Posted May 30, 2013 Report Share Posted May 30, 2013 Yes - phantom powered mics, T-powered mics (with an appropriate converter barrel), some dynamic mics without damage. No - wireless systems, actually just about everything else. To resolve pairs - either use it with something that can take phantom, block it, or don't use that input... Quote Link to comment Share on other sites More sharing options...
studiomprd Posted May 30, 2013 Report Share Posted May 30, 2013 " i have had conflicting advice and opinions " and more of the same, here... " What is the best (cleanest, lightest, lightest ) way to resolve the issue of switched pairs? " some mixers have a single switch for Phantom on all inputs. " A external phantom power box or phantom power filter or isolation transformer. " yes, ?, yes " No - wireless systems, actually just about everything else. " er, not really. a major feature of Phantom power is that,by design it is invisible to, and does not typically have any affect on a properly balanced & floating source. another feature is very limited current capability. There are exceptions, notably, non-transformer outputs of some mixers may react poorly (but not damage!) if plugged into a recorder input with Phantom power present. Also not recommended for older ribbon mic's. Quote Link to comment Share on other sites More sharing options...
daniel Posted May 31, 2013 Author Report Share Posted May 31, 2013 Thank you both helping clear this up. As an aggregate, all the details add up :-) And of course ultimately 'it depends'. I was planning on getting a phantom power box any way, it just occurred to me there maybe a way to block the PP on the 2nd I/P that would be convenient for a small recorder bag eg. small and light. And in the other direction i was also looking at Prefer MBF - 10? As an outboard pre-amp (with PP, LCF and int & ext power supply), its not a great shape for bag though. Thanks again. Atb, Dan Quote Link to comment Share on other sites More sharing options...
WhyOne Posted May 31, 2013 Report Share Posted May 31, 2013 Phantom powering (48 or 12VDC between pins 1 and 2, and 1 and 3) is used primarily because it won't damage most non-condenser mics, whereas T power (Tonader - 12VDC between pins 2 and 3) will toast a ribbon mic immediately! In today's world, Phantom power is safe with virtually all mics, but interestingly enough, some electronically balanced outputs can be adversely affected by Phantom power (xfmr balanced outputs couldn't care less...), most notably the Lectro Venues, which can be damaged when connected to a hot Phantom powered input. Jay Quote Link to comment Share on other sites More sharing options...
AnthonyTodaro Posted May 31, 2015 Report Share Posted May 31, 2015 I realize this is an old thread, but if by chance someone knows, has anyone experienced noise issues with the phantom power on the DR-680? Quote Link to comment Share on other sites More sharing options...
Shastapete Posted May 31, 2015 Report Share Posted May 31, 2015 Yes, pro-sumer quality lav receivers get a squirrelly sounding interference when fed phantom (no issue with lectrosonics) with my old dr-680 and G3 setup I couldn't use input 2 for wireless if I was powering a boom. this is also true with the newer Sony digital wireless (yellow screen) Quote Link to comment Share on other sites More sharing options...
