arri Posted June 8, 2013 Report Share Posted June 8, 2013 As the title says I can`t control the headphones out.I hear steady in the same volume.No min-no max.Any thoughts? Quote Link to comment Share on other sites More sharing options...
aristotle_kumpis Posted June 11, 2013 Report Share Posted June 11, 2013 Are you using the Tascam controller, and plugging your headphones into that? Or are you just using the headphone jack on the front of the recorder? Quote Link to comment Share on other sites More sharing options...
arri Posted June 11, 2013 Author Report Share Posted June 11, 2013 I am using the headphone jack on the front of the recorder.Any idea?I am in the middle of feauture film and I dont what to do!! Quote Link to comment Share on other sites More sharing options...
studiomprd Posted June 11, 2013 Report Share Posted June 11, 2013 It was working properly "before" ?? you have tried the DS Ultra Master reset sequence ?? maybe this is a case of "CRAP Happens.. it is broken Quote Link to comment Share on other sites More sharing options...
aristotle_kumpis Posted June 11, 2013 Report Share Posted June 11, 2013 Are you recording a mix track? If so, make sure you are sending the ISO tracks to the master bus. If you solo a track, make sure the solo send level is turned up. Quote Link to comment Share on other sites More sharing options...
arri Posted June 12, 2013 Author Report Share Posted June 12, 2013 Hello guys! No problem with my recorder before.Everythig was perfect! What is the DS Ultra Master reset sequence? I am not recording mix track.Just iso tracks. Quote Link to comment Share on other sites More sharing options...
aristotle_kumpis Posted June 12, 2013 Report Share Posted June 12, 2013 Not sure. I suggest you message Tom Duffy on this board. He works for Tascam and is extremely knowledgeable about the HS-P82. I've never had issues with mine as of yet. Quote Link to comment Share on other sites More sharing options...
studiomprd Posted June 12, 2013 Report Share Posted June 12, 2013 the OP has said it: "Malfunction" Quote Link to comment Share on other sites More sharing options...
Tom Duffy Posted June 19, 2013 Report Share Posted June 19, 2013 Been away on Vacation. Sounds like a malfunction to me, needs inspecting internally for problems. Tom. Quote Link to comment Share on other sites More sharing options...
