Vincent R. Posted July 2, 2013 Report Share Posted July 2, 2013 It's really good stuff. You never go back to what u used before Quote Link to comment Share on other sites More sharing options...
Matthias Richter Posted July 2, 2013 Report Share Posted July 2, 2013 I use Leukosilk since years as my standard tape too. Sometimes Leukoflex which is transparent. Quote Link to comment Share on other sites More sharing options...
BudRaymond Posted July 3, 2013 Report Share Posted July 3, 2013 I've started using the Original Pink Tape. It's usually for sport's applications, but it seems stickier than Transpore. Quote Link to comment Share on other sites More sharing options...
Blas Kisic Posted July 11, 2013 Report Share Posted July 11, 2013 I know I have several rolls of Transpore (a medical tape) but I'm not sure that's what we use. I know we do use Top Stick and a variety of other things depending on how it has to be mounted. Also, Rycote Stickies and Overcovers and Undercovers (or whatever they are called). transpore.jpg +1 on the Transpore. I use that 90% of the time, although I also have other medical-type tapes and, obviously, Top Stick. HTH, BK Quote Link to comment Share on other sites More sharing options...
Michael Miramontes Posted July 11, 2013 Report Share Posted July 11, 2013 I was wondering the same thing. +1. Transpore does come off easily as soon as the actor starts sweating. Now that it's summer the sweat factor is all too common. I wonder if talent would be offended if I started wearing latex gloves when I took their mics off? haha Quote Link to comment Share on other sites More sharing options...
TomBoisseau Posted July 11, 2013 Report Share Posted July 11, 2013 +1. Transpore does come off easily as soon as the actor starts sweating. Now that it's summer the sweat factor is all too common. I wonder if talent would be offended if I started wearing latex gloves when I took their mics off? haha I use the transpore tape alot, however its mainly to secure the lav cable to clothing. I have found, due to the fact that the transpore tape is rather porous, that it is also slightly rough and can cause noise problems if used right at the microphone. For securing the actual mic element, my go to is moleskin, although I do really like the little rubber COS11 holders. Tom Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted July 11, 2013 Report Share Posted July 11, 2013 For securing the actual mic element, my go to is moleskin, although I do really like the little rubber COS11 holders. A bit of topstick on the rubber mount usually works for me - I find it is generally sweat proof. Quote Link to comment Share on other sites More sharing options...
TomBoisseau Posted July 11, 2013 Report Share Posted July 11, 2013 A bit of topstick on the rubber mount usually works for me - I find it is generally sweat proof. That's exactly what I use as well. Tom Quote Link to comment Share on other sites More sharing options...
John Blankenship Posted July 11, 2013 Report Share Posted July 11, 2013 3Ms surgical tapes include: Micropore -- a paper tape Transpore -- a plastic tape Durapore -- a silk-like cloth tape I've used all three, but my current "go-to" is Durapore. A question to those who like Leukosilk is, "Have you compared Durapore to Leukosilk. They would appear to be similar products (to answer someone's question above, about what's similar in the U.S.). Durapore is readily available here in the states, even at drug stores -- and the big chains even have their own version of it. If you've compared them, does Leukosilk stick any better than Durapore? Is it quieter? Or, are they pretty much the same thing? Inquiring minds want to know. Thanks. I may have found a source for Leukosilk here in the U.S., so if it's better I'll sure give it a try. I do like the easy availability of Durapore (and its sibling "pores"). Quote Link to comment Share on other sites More sharing options...
Vincent R. Posted July 11, 2013 Report Share Posted July 11, 2013 Leukosilk works perfectly on skins as well. It sounds you have a match with the 3M variant Quote Link to comment Share on other sites More sharing options...
Nick Campbell Posted July 12, 2013 Report Share Posted July 12, 2013 I was a nursing assistant for a number of years, and in my time in those trenches I really liked 3m Medipore. I've used it successfully for lav's as well. It holds up very well and is tried and tested with a lot of gushing wounds and showers. Pros: -It's perforated (no fumbling with scissors or teeth) -Comes in a variety of widths -It has great water resistance. As long as you're applying it to dry skin, it holds up pretty well to sweat. -It moves with the skin. I find this to be the real factor for medical tape staying on. Stiffer, non-cloth tapes will start wearing at the edges faster and forming creases, which allow water and sweat in. -It comes off gently with no residue (also in case you didn't know when taking off bandages: always pull the skin away from the bandage, not the other way around) -Pretty affordable Amazon sells it as do most medical supply shops. Give it a try. Quote Link to comment Share on other sites More sharing options...
greg sextro Posted July 12, 2013 Report Share Posted July 12, 2013 ...loving this thread. Lots of new stuff to try. Quote Link to comment Share on other sites More sharing options...
Olle Sjostrom Posted October 30, 2013 Report Share Posted October 30, 2013 Using this tape. It's a great double sided tape. Just a tip! And it's called Tesa 4965 if you were wondering Quote Link to comment Share on other sites More sharing options...
soundtrane Posted October 30, 2013 Report Share Posted October 30, 2013 TESA 4965 - Olle, is it easy to tear with your fingers? Quote Link to comment Share on other sites More sharing options...
Olle Sjostrom Posted October 30, 2013 Report Share Posted October 30, 2013 Nah.. You'd need scissors.. Quote Link to comment Share on other sites More sharing options...
BVS Posted October 30, 2013 Report Share Posted October 30, 2013 There's a wig shop not far from my place...I walk in and say..."I'm looking for some wig tape".... The guy looks at me and looks again...and then again.... Then he says.." That's the best dam wig I've ever seen !!!! " BVS Quote Link to comment Share on other sites More sharing options...
Toy Robot Posted November 1, 2013 Report Share Posted November 1, 2013 There's a wig shop not far from my place...I walk in and say..."I'm looking for some wig tape".... The guy looks at me and looks again...and then again.... Then he says.." That's the best dam wig I've ever seen !!!! " BVS Nice! Quote Link to comment Share on other sites More sharing options...
John Blankenship Posted November 2, 2013 Report Share Posted November 2, 2013 This might be of interest: I've used, and carry, several of the above including Medipore, Micropore, Durapore, and Transpore, and my "go-to" is still Durapore. I've only just added Medipore, as well as 3M Nexcare "absolute waterproof first aid tape," so don't have a well-formed opinion on those yet. I normally use these tapes just for lav cable control. However, for actually attaching lavs I employ a combination of mole skin, Overcovers, and Super Stick-It when called for. Quote Link to comment Share on other sites More sharing options...
atheisticmystic Posted November 2, 2013 Report Share Posted November 2, 2013 Thanx, JB, nice chart. I started using Nexcare recently, and am interested to learn how you like it. The hold is sometimes too good, sticking hard to some fabrics (will have to remember to note which), and when accidentally stuck to itself around the lav cable is a bit of a pain, and I've noticed a few irritations on skin (but no complaints). best Quote Link to comment Share on other sites More sharing options...
John Blankenship Posted November 2, 2013 Report Share Posted November 2, 2013 Here's a link to the brochure I pulled the chart from: http://tinyurl.com/nf7o58z It has a variety of info and other charts that folks might find informative. Quote Link to comment Share on other sites More sharing options...
al mcguire Posted November 3, 2013 Report Share Posted November 3, 2013 They don't label the vertical axis, so what is a measuring unit of adhesion ? stickies adhesivo's Quote Link to comment Share on other sites More sharing options...
jackdrobin Posted November 4, 2013 Author Report Share Posted November 4, 2013 Great chart John, cheers! --what is a measuring unit of adhesion ? Clingons? Quote Link to comment Share on other sites More sharing options...
aginzo Posted November 6, 2013 Report Share Posted November 6, 2013 For a lot of my work I used moleskin and I sandwich the lav with 2 pieces one on top of the mic and one behind it. Then on the one behind it take of the sticky adhesive backing and stick to the chest or bra of talent. Works 9 times out of ten. I still like to use Topstick for tie rigs and sometimes will use Transpore. http://www.soap.com/p/dr-scholls-moleskin-plus-roll-50605?site=CA&utm_source=Google&utm_medium=cpc_S&utm_term=SP-128&utm_campaign=GoogleAW&CAWELAID=1323207098&utm_content=pla&adtype=pla&cagpspn=pla Quote Link to comment Share on other sites More sharing options...
John Blankenship Posted November 6, 2013 Report Share Posted November 6, 2013 Great chart John, cheers! --what is a measuring unit of adhesion ? Clingons? Yeah! Quote Link to comment Share on other sites More sharing options...
Blas Kisic Posted November 6, 2013 Report Share Posted November 6, 2013 Great chart John, cheers! --what is a measuring unit of adhesion ? Clingons? "Sticktoitiveness"? Quote Link to comment Share on other sites More sharing options...
