guynoir Posted July 11, 2013 Report Share Posted July 11, 2013 Hi All, Ok, I've seen in the version notes where remote transmitter frequency changing is supposedly possible with the Zaxcom wireless transmitters. This feature is at best undocumented beyond the rev. notes. Does it really exist, and how does one do such a thing!? I've got TRX900LAs, a 942 and IFB100 Thanks, John Quote Link to comment Share on other sites More sharing options...
Zack Posted July 11, 2013 Report Share Posted July 11, 2013 Um.... ya it's very possible among other things you can also do. I do it from Nomad or from QRX ifb. Quote Link to comment Share on other sites More sharing options...
John Blankenship Posted July 11, 2013 Report Share Posted July 11, 2013 You can remotely change frequencies, adjust the transmitter's gain, put the transmitter to sleep, wake the transmitter up, and have it brew a delicious cup of coffee on a cold winter day. NOTE: Remote coffee brewing is not yet implemented. It'll reportedly be ready by NAB. There are various threads either here or on the Zaxcom forum about how to set up a transmitter to do such things. Quote Link to comment Share on other sites More sharing options...
Zack Posted July 11, 2013 Report Share Posted July 11, 2013 Maybe one day they can not only generate sound reports, but include an invoice too Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted July 11, 2013 Report Share Posted July 11, 2013 http://www.zaxcom.com/instruction-manuals Check out the latest Zaxcom manuals - it is fairly well documented. Quote Link to comment Share on other sites More sharing options...
Johnathan Sessoms Posted July 11, 2013 Report Share Posted July 11, 2013 All possible! Better yet, with the built in recorders, the range is ultimately limitless! Quote Link to comment Share on other sites More sharing options...
Constantin Posted July 11, 2013 Report Share Posted July 11, 2013 Although the range of the remote control is anything but limitless Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted July 11, 2013 Report Share Posted July 11, 2013 All possible! Better yet, with the built in recorders, the range is ultimately limitless! Very well put. Quote Link to comment Share on other sites More sharing options...
ao Posted July 19, 2013 Report Share Posted July 19, 2013 I was reminded of this fact when I had remotely powered off a trx900lt (trying to match a 5hr battery life with a 6hr "morning"). when asked to awaken, it would not. the transmitter was buried in a spanx-type garment and not accessible. fortunately, it was the actress' close-up.... ao Although the range of the remote control is anything but limitless Quote Link to comment Share on other sites More sharing options...
soundslikejustin Posted July 19, 2013 Report Share Posted July 19, 2013 Did it run out of battery life while in Low Power mode? LOW2 uses approximately 50% power. 'Start in Remote Boot' mode uses 25%. I was reminded of this fact when I had remotely powered off a trx900lt (trying to match a 5hr battery life with a 6hr "morning"). when asked to awaken, it would not. the transmitter was buried in a spanx-type garment and not accessible. fortunately, it was the actress' close-up.... ao Quote Link to comment Share on other sites More sharing options...
ao Posted August 14, 2013 Report Share Posted August 14, 2013 Did it run out of battery life while in Low Power mode? LOW2 uses approximately 50% power. 'Start in Remote Boot' mode uses 25%. I was in low2, and the battery did show life, although with lithium batteries, that can be misleading towards the end of it's life. thanks for the remote boot tip. ao Quote Link to comment Share on other sites More sharing options...
soundslikejustin Posted August 14, 2013 Report Share Posted August 14, 2013 I was in low2, and the battery did show life, although with lithium batteries, that can be misleading towards the end of it's life. thanks for the remote boot tip. ao Just for clarification, I named it wrong. The menu setting is 'Boot up in' and the options are 'Normal Mode', 'Standby Mode' and 'Remote Standby'. You want Remote Standby, and then you need to send a 'Wake' command to start it up - using the standard 'ON' command doesn't do it. Quote Link to comment Share on other sites More sharing options...
Jan McL Posted August 14, 2013 Report Share Posted August 14, 2013 Are you all good now, John? Quote Link to comment Share on other sites More sharing options...
guynoir Posted August 20, 2013 Author Report Share Posted August 20, 2013 "I don't know" is a perfectly OK answer. Found it on page 61 of Zaxcom Digital Wireless System Transmitter User's Manual, which is apparently now out of print. After poring over several hundred pages of other manuals. Quote Link to comment Share on other sites More sharing options...
John Blankenship Posted August 20, 2013 Report Share Posted August 20, 2013 For the IFB100 to control your transmitters, you need to have both the GROUP CODE and UNIT CODE set on both the IFB100 and the transmitters. If you want to control, for instance, three transmitters, set the GROUP CODE to 1 (or whatever number you choose) on all the transmitters and on the IFB100. If you wish to be able to control each transmitter individually, set the UNIT CODE to a different number for each transmitter. Note: To change a transmitter's frequency via an IFB100, you need to select which transmitter. In other words, if: REMOTE CONTROL UNIT ID=ALL then the frequency set option won't show up. If you select, let's say, transmitter #3 as follows: REMOTE CONTROL UNIT ID=0003 then you can hit menu until you reach the screen that says: REMOTE CH ###.# UNIT ID=3 000 (###.#, of course is a frequency.) If you use the up and down arrow keys you can set this to another frequency and the corresponding number transmitter will switch to that frequency. Quote Link to comment Share on other sites More sharing options...
