I've just ordered a second QRX (I already own one with IFB Option), but I wasn't able to get infos from my seller about the usb cable to link the receivers in order to use the one with the ifb transmitter for them both.
Actually, I also asked Zaxcom (no detailed info on the user guide too) but it seems they don't provide that cable.
So, is there someone here that use this configuration and would tell me which is the cable and connector parts required for the matter?
Thanks,
v.
Thanks all.
When I read this on the last QRX manual
post-1382-0-25103500-1374306488_thumb.pn
I thought some special cable was involved, not only a different wiring.
So, basically, can I use a common cable, just rewired correctly, right?
thanks, again.
v.
Thanks all.
thanks, again.
v.
Right. The wording of that sentence is poor. The connectors are 'generic' USB connectors, they are just wired differently. A 'generic' USB is wired:
1-1
2-2
3-3
4-4.
The Zaxcom serial connection is wired:
OUT to IN
1-NC
2-1
3-4
4-NC
The warning about them not being USB connectors is very misleading.  It should state that this is not a USB BUS, it is a RS422/RS485 BUS on standard USB connectors.
If you have problems making the cable, I'd be happy to make you some.  PM me if you want.
K
Thanks,
I will give a try to myself and if I'll be not able to make it work, I'll write you for sure.
K
Wandering Ear made some for me.
Hey Jan,
Thanks for the recommend by the way. Are you using the cables? How do you like controlling the transmitters through the QRX? I've done it in testing, but haven't tried it in the field.
  • 1 year later...
Hey Jan,
Are you still making these usb cables?
  • 4 months later...
Back on this topic please. I'm in the process of trying to make a cable to connect my Nomad to RX-12. Can I use this same method for the cable? I'm working in a small town so I only have access to Walmart. The only USB cable they sell is a printer cable. I wonder if I can buy two of those and splice them??
I'm not sure that the serial connection between Nomad and RX-12 is the same as between the QRX's, but yes, buying two cables and splicing them in the required connection will work fine.
