Hiding Mics on Soccer Players
ncsoundmixer
Hi Folks
I've been asked to work on a documentary following a soccer team through its season.
The director wants to hidden body mic key players during practice and games.
I have put mics on athletes before - even with "clean" hidden mounts I tend to hear the jersey flapping/bouncing on and off the chest, with both sternum mounts and when taping or vamping the mic on the uniform, especially as the jersey becomes soaked with sweat.
Sternum mounts with tape tended not too last long before the sweat eliminated the stick from the tape and the mount comes off. I've use Tegaderm, Moleskin, toupée tape, etc., all with similar results.
Vampire clips at the collar tend to keep the mic in place but the bouncing and flapping of the jersey was still an issue.
Anyone have a magic bullet?
I have also thought about getting a parabolic mic worked from the sideline as an alternative.
TIA
I just had some experience with lav'ing up pro soccer players a few weeks ago. I do house sound for a pro soccer stadium in Philly and the in house production crew was testing out the Q5x wireless systems for capturing in game audio for some shorts they were producing. They had great results with their mounting approach and this is what they did;
They mounted the mic semi permanently inside a tight, form fitting Under Armor shirt the player wore under his usual jersey. I believe they sewed a small pocket for a B6 head (heavily taped down with moleskin and then sewn shut i believe.) They sewed another channel in the shirt to run the cable through so there was no chance of it hanging loose, getting ripped out Etc. They ran the cable channel to a neoprene pocket sewn on to the shirt around the small of the back for the transmitter. This shirt kept the mic head nice and tight to the body for no flapping and since there was no exposed tape it didn't get dismounted by sweat. I monitored the audio for most of the game and surprisingly never really heard any clothing rustle or bouncing except for when players brushed against it hit the mic itself. This rig also made it incredibly easy to have an all in one, pre rigged shirt that they could just pass off to any player and they could be rigged and ready to go in about 10 seconds.
I would also definitely look into renting or buying a q5x system for this type of job. A hard metal transmitter attached to an athlete during gameplay or even practice is a big liability. One bad fall or hit in the back could cause some serious physical injury. The Q5X transmitters are rubber, small, flexible and designed for sports. Just throwing that out there. http://www.q5x.com/wireless-audio-solutions/wireless-audio-for-sports/
Good luck and let us know how it goes!
Well Matt sure provided an authoritative answer (thanks). Matt, did you ever get any complaints from the players about the underarmour shirt making them too hot?
Brooks, if you have time to kill you might also want to check out this recent discussion about mic'ing Australian Rules Football players (actually, I thought it was a pretty good thread):
By the way, hey Brooks! I just put two and two together as to who I was responding to. Hope all is well!
Not sure if there were any complaints about the warmth of the extra shirt. I wasn't really involved with the process after everything was setup and routed through my board.
Matt -
Thanx for the info - and it's great to hear from you!
I'll investigate the Under Armour base layer solution. Do you (or anyone else) have pix of the mic mount in the sewn-in pocket? I'd really like to see an actual image of the set up - I'm most interested in the mic mount aspect.
Thanks again, hope we get to work together soon!
I have had good luck with tape or moleskin directly to the inside of the jersey.  It will vary some depending on the material but I have found that for tennis and soccer players this works much better than going to skin as the sweat becomes an issue.  Also this needs to be applied before they start sweating too much into the shirt for the same reasons.
I've had good luck with Kinesio tape on the bodies of sweaty athletes. And these days, many athletes are used to having that stuff all over their bodies. There are a couple threads here on JWS with more sound-specific info, but to start:
http://en.wikipedia.org/wiki/Elastic_therapeutic_tape
But Matt's vest idea is great if the athlete is OK wearing it.
I too recently did a job for the WNBA and the NBA sound tech used the same Q5x system, worked like a charm on star player coach and lead referee...I monitored all game and heard no rustling issue at all, same technique, lots of moleskin with a b-6 in a cage sewn into the jersey and the TX sits in a sewn in neoprene pouch! JHW
I heard from a fellow mixer who does a lot of sports that all NBA jerseys come manufactured with channels specifically designed for running lav cables, that way they can wire any player without fiddling with special uniforms. Did you find it true with the WNBA?
Wonder what the cage was made out of, looked like?
Usually on refs and coaches we use a tie clip reg transmitters. On players we use the Q5 trans in a neoprene sleeve that fits in a pocket sewn in the underarm area of the Jersey. We use lots of moleskin to hold down the cable and a Countryman B6 (the mic and battery are built into the trans) are connected to the collar with a  small coat hook (Black brass Dritz brand coat hooks and eyes) crimped on the head of the mic. All wrapped in moleskin. Jersey's are pre-rigged one for first half and one for second half.  The only cage I guess would be the small coat hooks that hold the mic head in on the collar. The transmitters are very thin and light- when we have them rigged up it's hard to notice they're there. I worked wireless for NBAE at All Star week this last season in Houston.
Yes Dan is at the top of the NBA call list, and a great guy! I last worked with him at the NBA finals he and I took care of recording the radio feeds and coaches/ ref mics on to two 744's. As well the usual ENG stuff pre and post game. The NBA has developed a system of doing it (attaching mics on jersey's) and they don't want you to stray far from the system- if it's not broke don't try to fix it. John next time you see him tell him I said "Hi"
Allen Green/ Texas soundguy.
...and a Countryman B6 (the mic and battery are built into the trans) are connected to the collar with a small coat hook (Black brass Dritz brand coat hooks and eyes) crimped on the head of the mic. All wrapped in moleskin...
Found these...
http://www.dritz.com/brands/dritz/products/dr97-1_l.jpg
Would love to see a pic how this rig looks.
best
