JWL
In ear Cueing
Hi guys,
firstly, apologies if this topic already exists, i have searched with no luck.
My question is, what have members found to be the best in ear cueing system (wireless).
i am working on a show where people conduct interviews but the interviewer is being told what to say from another room.
 i have heard of the comtek style in ear systems whre the person wears an earwig and has a loop around there neck connected to an ifb reciever which transmitts to the earwig.
the production had been trying a similar system with the neck loop and earwig, with the neck loop connected to an iphone but they have been finding it too quiet for the interviewer.
what have you peolple found has worked for you.
CHeers guys, Jeremy.
I have two of these, English made
I developed my own inductors fitted in the collar of shirt with a vampire clip
You must feed these at max level but it works well
mike
" Any other products you man know that are under $1500 usd. "
"yeah, what you are currently using."
Sometimes your comments are so helpful senator that i find it overwhelming. So helpful. Thanks, that comment really solved the problem.
If the phone isn't driving the induction loop hot enough, you could try adding an external in-line amplifier.
A quick google search will turn up options from the hi-fi crowd... To not so hi-fi. Maybe start cheap to see if you get the desired result.
Or you could try after all what Senator suggested and try another IEM receiver. The Sennheisers have a pretty good output level. Might be a bit less clutter than a phone with an amp - but more expensive, too. But again less than 1500
Thanks thats all very helpful.
I have no shortage of radio mics. Im running a 552 with 4 smv's on talent and 2 srb's in the bag. Wiresless to cam on another srb.
I was just mainly wanting to know what people have found to be the clearest in ear earwig neck loop system before i purchased one.
I think ill try the in line amplifier first.
Then probably buy the raycom if that does not work. Just dont think the raycom will work with my lectro trx's.
Thanks guys, great advice.
Hey JWL. quick question for clarification: is the interviewer on-camera? ie. 2 camera interview? if you don't see him/her and you don't have to worry about hiding an earwig, could a bluetooth headset from the mobile phone work?
I'm due to start working with an actor who I'm told uses some kind of behind-the-ear cueing system.  As in not something inserted into the ear canal but something that hangs off of and behind the ear.  Does anyone know what this system might be?
Could be bone conductive ear pieces. I believe they have both in ear and around the ear.
Maybe they got their hands on a Bone Conduction hearing aid like Adhear https://www.medel.com/hearing-solutions/bone-conduction-system
Thanks for the thoughts re: Bone conductive ear pieces.  That does seem to be the way in which you could hear from behind the ear.  Unfortunately I cannot find any system that doesn't rely on bluetooth for sending audio to them.
Still no luck on the search for whatever this system may have been.  I'll go with a Phonak.  On a separate but related issue, has anyone found a push-to-talk electret 2-wire mic that works well with a Comtek BST-75 transmitter?  I'm trying to build a streamlined portable setup for the cueing side.   Was hoping to avoid needing to power and include a separate mic pre-amp for this.
