Ju Griz Posted October 28, 2013 Report Share Posted October 28, 2013 ...and I found this. I'm probably not going to buy it any time soon, but it's so beautiful I had to share it. Reading the specs, it only takes .wav and .flac files. Any thoughts on it? <http://www.colorfly.eu/product_index.html> Quote Link to comment Share on other sites More sharing options...
daniel Posted October 28, 2013 Report Share Posted October 28, 2013 Slick, and suitably niche - it's got a fader, you get to use a converter (if you've need to get your ears dirty with mp3 source material and there is something reassuringly familiar about about the sales patter: We have been using the Colorfly C4 for quite a while and have established that there are a few quirks with the device. We wish to let you know of these prior to us sending you the unit as there has been some conflicting information in recent press releases. The Colorfly C4 will not play high resolution .flac files. It will play .flac, however it will only play up to 16bit/44.1kHz. It will however play 24bit/192kHz high resolution .wav files. We have found that using Media Monkey is the best way to transfer your files to the Colorfly C4 so that they are in order when being played back. If you do have high definition .flac files that you would like to play on the Colorfly C4 then in order to convert to .wav we suggest using a freeware program called xrecode. With the current firmware there is also a small noise that can be heard between tracks that is due to be resolved with the next firmware update! After stating this we still remain with the opinion that the Colorfly sounds absolutely amazing and you will be thoroughly impressed with the sound reproduction. dan. Quote Link to comment Share on other sites More sharing options...
