Diego Sanchez Posted November 4, 2013 Report Share Posted November 4, 2013 Hello everyone. I normally don't use the mix assist function on my 788, but have a job coming where it will be beneficial. I was trying it and whenever i tried to activate it, it says to lower the sample rate or number of media or disable output delays. The only way i get it to work, is if i lower sample rate to 44.1 which is not something i want to do. Anyone has any idea why and how i can get it to work on 48/24? thanks Diego Quote Link to comment Share on other sites More sharing options...
VASI Posted November 4, 2013 Report Share Posted November 4, 2013 Page 39 manual: Mix Assist is a processor-intensive feature. Mix Assist is disabled when the sampling rate is above 48.048 kHz. Recording mono files is not recommended when using Mix Assist. Output Delay is not recommended when using Mix Assist. When a CF card is in use, UDMA is recommended. Quote Link to comment Share on other sites More sharing options...
Diego Sanchez Posted November 4, 2013 Author Report Share Posted November 4, 2013 yes i can read that, i'm recording 2 channels, at 48.000 and there is no output delay, so it should work. Quote Link to comment Share on other sites More sharing options...
VASI Posted November 4, 2013 Report Share Posted November 4, 2013 CF card? Quote Link to comment Share on other sites More sharing options...
pkautzsch Posted November 4, 2013 Report Share Posted November 4, 2013 it says to lower the sample rate or number of media or disable output delays at 48.000 and there is no output delay Are you trying to record to all three media? IIRC this doesn't work. Mix Assist has been working fine in my setup: 48,000 Hz, 24 bits, poly WAV, record to INHDD and CF. I record up to 8 ISO tracks, 2 Mix tracks, and route different mixes to both AUX tracks for comtek feeds (not recorded - use the AUX routing because it's quicker than the output routing matrix). Quote Link to comment Share on other sites More sharing options...
Matt Mayer Posted November 4, 2013 Report Share Posted November 4, 2013 Make sure Menu 7 : Media Select isn't set to "EXHDD and INHDD and CF". Even if all three media aren't present, this will throw the error you are seeing. Quote Link to comment Share on other sites More sharing options...
VM Posted November 4, 2013 Report Share Posted November 4, 2013 I use it many times at 24b/48k INHDD plus EXHDD on 8 channels. Quote Link to comment Share on other sites More sharing options...
Diego Sanchez Posted November 5, 2013 Author Report Share Posted November 5, 2013 Make sure Menu 7 : Media Select isn't set to "EXHDD and INHDD and CF". Even if all three media aren't present, this will throw the error you are seeing. Thanks Matt and everyone. Yes that was the problem, even if the external media was not present, having it active on this menu was the problem. All systems good! Quote Link to comment Share on other sites More sharing options...
RPSharman Posted November 5, 2013 Report Share Posted November 5, 2013 Good to know! Quote Link to comment Share on other sites More sharing options...
afewmoreyears Posted November 5, 2013 Report Share Posted November 5, 2013 Definitely... you learn something new every day... Quote Link to comment Share on other sites More sharing options...
chris_bollard Posted November 6, 2013 Report Share Posted November 6, 2013 Yep. Mix assist can be picky. Slow media usual culprit. As is often said here it depends & your mileage may vary. For two tracks I'd mix manual and keep ISO as backup. Used it with sone success on 8 person panel discussion, but I did have to tweak a bit for best results Quote Link to comment Share on other sites More sharing options...
