Takuro Kochi Posted November 8, 2013 Report Share Posted November 8, 2013 (edited) JL cooper MCS-Pro FaderMaster Professional http://www.jlcooper.com/_downloads/mcsproseries/r88_fademaster_setup.pdf Edited November 12, 2015 by Takuro Kochi Quote Link to comment Share on other sites More sharing options...
Takuro Kochi Posted November 13, 2013 Author Report Share Posted November 13, 2013 Today, I went to Inter BEE 2013 in Japan. Roland R-88 MIDI Fader UnitTOMOCA TMF-08-R 126,000 yen Quote Link to comment Share on other sites More sharing options...
daniel Posted November 14, 2013 Report Share Posted November 14, 2013 Today, I went to Inter BEE 2013 in Japan. Roland R-88 MIDI Fader UnitTOMOCA TMF-08-R 126,000 yen Isn't this quite expensive for a midi fader board? dan Quote Link to comment Share on other sites More sharing options...
studiomprd Posted November 14, 2013 Report Share Posted November 14, 2013 " Isn't this quite expensive for a midi fader board? " that is difficult to say... Quote Link to comment Share on other sites More sharing options...
Constantin Posted November 15, 2013 Report Share Posted November 15, 2013 " Isn't this quite expensive for a midi fader board? " that is difficult to say... Not if you have access to a currency converter. The Midi port on the R-88 is actually a pretty good idea, depending on the protocol. It could allow access via dozens of low-cost and more expensive midi controllers. Motorized fader panel? Quote Link to comment Share on other sites More sharing options...
Takuro Kochi Posted November 15, 2013 Author Report Share Posted November 15, 2013 Not if you have access to a currency converter. The Midi port on the R-88 is actually a pretty good idea, depending on the protocol. It could allow access via dozens of low-cost and more expensive midi controllers. Motorized fader panel? It's no motorized fader. My friend made request, need mute and solo button. I asked Question to Roland Staff, Now Roland dose not make a R-88's mixer. Quote Link to comment Share on other sites More sharing options...
Constantin Posted November 15, 2013 Report Share Posted November 15, 2013 It's no motorized fader. My friend made request, need mute and solo button. I asked Question to Roland Staff, Now Roland dose not make a R-88's mixer.No, I know it's not motorized. What I meant was if the R88 supports well-known Midi Control formats, such as HUI, then any Midi controller could be used. Even one with motorized faders. If it only supports proprietary formats, I'd question the use of a Midi port... Quote Link to comment Share on other sites More sharing options...
Sound Man Posted November 15, 2013 Report Share Posted November 15, 2013 I asked Question to Roland Staff, Now Roland dose not make a R-88's mixer. Thats a news !!! Quote Link to comment Share on other sites More sharing options...
Philip Perkins Posted November 15, 2013 Report Share Posted November 15, 2013 So it doesn't make the R88 a mixer? What does it do then--just ride input trim gain? Are you sure that it make a mix down of the post-trim post ISO inputs to a stereo bus/track? No solos is kind of a bummer. philp Quote Link to comment Share on other sites More sharing options...
Constantin Posted November 15, 2013 Report Share Posted November 15, 2013 The R-88 already has a mixer built in. That can be controlled via the midi interface. And it can record a stereo mixdown in addition to the 8 iso tracks - if I read their website correctly. So this whole Midi thing is actually a pretty cool idea, I think, depending on the implementation Quote Link to comment Share on other sites More sharing options...
Takuro Kochi Posted April 6, 2014 Author Report Share Posted April 6, 2014 Roland R-88 fader. I use iOS app(Lemur) Fader is about 100mm. mute button (solo botton is difficult. MIDI signal is sent only ) https://www.youtube.com/watch?v=_euGW6sssw8&feature=youtu.be Quote Link to comment Share on other sites More sharing options...
Takuro Kochi Posted June 9, 2014 Author Report Share Posted June 9, 2014 Roland R-88 fader Unit Base ( use iPad2) Quote Link to comment Share on other sites More sharing options...
greyfoxx Posted June 19, 2014 Report Share Posted June 19, 2014 I am tempted to try Lemur for the R-88. I use the JL Cooper fader master pro and its actually pretty good but no solo. Seems the same with Lemur but at least I can throw my iphone in my bag and have a mini fader. Roland needs to give us something better than just faders and mutes. Quote Link to comment Share on other sites More sharing options...
Takuro Kochi Posted June 25, 2014 Author Report Share Posted June 25, 2014 I am tempted to try Lemur for the R-88. I use the JL Cooper fader master pro and its actually pretty good but no solo. Seems the same with Lemur but at least I can throw my iphone in my bag and have a mini fader. Roland needs to give us something better than just faders and mutes. Maybe It is possible. If you can use Lemur for the R-88, I help you. Quote Link to comment Share on other sites More sharing options...
opard Posted August 7, 2014 Report Share Posted August 7, 2014 Tried to connect my 1gen korg nanokontrol directly to r-88. Roland see it and I suppose it should work but I need to configure nanokontrol properly. I'm not good at midi. So I'll appreciate if anyone helps me find the right way of configuring. There is a R-88 MIDI Implementation list available online. And my nanokontrol accept CC commands. Is it possible to connect these devices? Quote Link to comment Share on other sites More sharing options...
resonate Posted August 9, 2014 Report Share Posted August 9, 2014 nano control 2 works, if there is a software for v1 that can map midi cc, i cannot see why it could not work...did you get it to work? Quote Link to comment Share on other sites More sharing options...
opard Posted August 9, 2014 Report Share Posted August 9, 2014 Does it connected directly or using roland um-one usb/midi accessory? I can configure CC comands using 'korg kontrol editor' but I don't know the required values for roland. Can you help with this? Quote Link to comment Share on other sites More sharing options...
resonate Posted August 11, 2014 Report Share Posted August 11, 2014 i believe you may want to see this (and other) roland's videos: Quote Link to comment Share on other sites More sharing options...
opard Posted August 13, 2014 Report Share Posted August 13, 2014 i believe you may want to see this (and other) roland's videos: Did you configure your nanokontrol2 or it just work with r88? I saw this video. It's specific to JLCooper config. Quote Link to comment Share on other sites More sharing options...
resonate Posted August 18, 2014 Report Share Posted August 18, 2014 I don't own the R88. You just have to experiment. buy the additional usb midi adapter and use the user manual & videos. Quote Link to comment Share on other sites More sharing options...
Takuro Kochi Posted December 9, 2014 Author Report Share Posted December 9, 2014 I made R-88 Wireless MIDI iPad Mixer. http://youtu.be/7jM6t0jwBCA Quote Link to comment Share on other sites More sharing options...
greyfoxx Posted December 10, 2014 Report Share Posted December 10, 2014 What device did you use for the wireless midi? Are you using Lemur for the IPAD? Quote Link to comment Share on other sites More sharing options...
Takuro Kochi Posted December 12, 2014 Author Report Share Posted December 12, 2014 Roland R-88 - Roland UM-ONE mk2 - Quicco mi.1 //wireless// iPad Air (Lemur) Quicco mi.1is midi bluetooth converter. https://www.indiegogo.com/projects/mi-1-wireless-midi-interface-connecting-digital-piano-and-ios-device Quote Link to comment Share on other sites More sharing options...
Takuro Kochi Posted January 8, 2015 Author Report Share Posted January 8, 2015 R-88 iPad MIDI Mixer Lemur file is available for download. http://surroundtokyo.com/?p=583 I use Lemur App. Quote Link to comment Share on other sites More sharing options...
