evolvmedia Posted December 13, 2013 Report Share Posted December 13, 2013 After shooting with the Canon C300 for the past several months with a 59.97nd frame rate. I'm now working on another show with it set up for 59.94nd. I'm trying to figure out the proper frame rate setting in the 664 to jam TC? Would I use 29.97nd or 30nd Thanks for your help! Damen Quote Link to comment Share on other sites More sharing options...
Marc Wielage Posted December 13, 2013 Report Share Posted December 13, 2013 There is no 59.97 TC rate (yet). There is a 29.97 timecode rate. There's also a 59.94 field rate (equivalent to a 29.97 frame rate). If you're shooting at 59.94, then I'd say use 29.97 timecode. But get it in writing from the editor and/or post supervisor first. And do a workflow test if possible. Quote Link to comment Share on other sites More sharing options...
Ze Frias Posted December 13, 2013 Report Share Posted December 13, 2013 And do a workflow test if possible. +1 Quote Link to comment Share on other sites More sharing options...
evolvmedia Posted December 13, 2013 Author Report Share Posted December 13, 2013 Marc, Thanks for the intel. You're correct I misspoke it was 29.97 with the c300 on the last shoot. But for this shoot I'll set up the 664 up for 29.97 until I hear from post. I'll see if I can do a test. thanks again. Quote Link to comment Share on other sites More sharing options...
BAB414 Posted December 13, 2013 Report Share Posted December 13, 2013 Using any of the Denecke devices, you can "cross jam" the camera from the box on the zero frame (automatically) and the camera will be in sync. Quote Link to comment Share on other sites More sharing options...
