Herbert Verdino Posted January 18, 2014 Report Share Posted January 18, 2014 Hey. I am using Lectro SMDa transmitters and now I want to use them for an wireless boom. Is there any different in sound compared to an HM plug on transmitter? Are you folks doing this, or is this a not very professional solution? Best! Quote Link to comment Share on other sites More sharing options...
Christopher Mills Posted January 18, 2014 Report Share Posted January 18, 2014 If combined with a power supply for your microphone, it works well. If you use a Sound Devices MM1, you can also run an IFB into the unit and hear both our mic and a feed from the mixer Quote Link to comment Share on other sites More sharing options...
jason porter Posted January 18, 2014 Report Share Posted January 18, 2014 Occasionally I use an SMV with an Ambient UMP-II power supply. No issues other than more weight at the business-end of the boom. Quote Link to comment Share on other sites More sharing options...
studiomprd Posted January 18, 2014 Report Share Posted January 18, 2014 (edited) HV: " Is there any different in sound compared to an HM plug on transmitter? " I think the SMD will sound flat, compared to the HM, which has a bigger, more full bodied sound. Edited January 19, 2014 by studiomprd Quote Link to comment Share on other sites More sharing options...
Herbert Verdino Posted January 18, 2014 Author Report Share Posted January 18, 2014 HV: " Is there any different in sound compared to an HM plug on transmitter? " the SMD will sound flat, compared to the HM, which has a more full bodied sound. ... so, you would choose a HM over a SMD if you had the choice? Quote Link to comment Share on other sites More sharing options...
studiomprd Posted January 18, 2014 Report Share Posted January 18, 2014 HV: " choose a HM over a SMD if you had the choice? " yes Quote Link to comment Share on other sites More sharing options...
Herbert Verdino Posted January 18, 2014 Author Report Share Posted January 18, 2014 If combined with a power supply for your microphone, it works well. If you use a Sound Devices MM1, you can also run an IFB into the unit and hear both our mic and a feed from the mixer ... couldn't I do the IFB monitor thing also with an HM? Quote Link to comment Share on other sites More sharing options...
dominiquegreffard Posted January 18, 2014 Report Share Posted January 18, 2014 ... couldn't I do the IFB monitor thing also with an HM? No boom up will need to wear a ifb pack then. Quote Link to comment Share on other sites More sharing options...
LarryF Posted January 18, 2014 Report Share Posted January 18, 2014 Hey. I am using Lectro SMDa transmitters and now I want to use them for an wireless boom. Is there any different in sound compared to an HM plug on transmitter? Are you folks doing this, or is this a not very professional solution? Best! The input circuity, limiter, DSP, filters, etc., are identical in the HM and SM series. The audio sounds the same. If identical signals are presented to the two transmitters, the results will be identical. Best Regards, Larry Fisher Lectrosonics Quote Link to comment Share on other sites More sharing options...
gpiegari Posted January 18, 2014 Report Share Posted January 18, 2014 ^ and that WAS from the manufacturer! Quote Link to comment Share on other sites More sharing options...
rich Posted January 18, 2014 Report Share Posted January 18, 2014 HV: " Is there any different in sound compared to an HM plug on transmitter? " the SMD will sound flat, compared to the HM, which has a more full bodied sound. i would have described it as bigger bodied. but if you want a sensible answer, then listen to Larry Fisher. advantage of using the SM transmitter is that you can use it as a bodypack when you dont need it for the boom. disadvantage is the extra weight of however you choose to power the mic. i'd look at the ambient UMP II as was already recommended. (i have 2) Quote Link to comment Share on other sites More sharing options...
Freeheel Posted January 18, 2014 Report Share Posted January 18, 2014 Thanks Larry for your contribution. Senator Tourettes, I can deal with your constant need for attention with posts that say nothing but fill space, but please try to refrain from spreading misinformation. I assume your Flat and Full bodied comment was based on some private hilarious joke regarding the shape of the different transmitters. But really you are just seriously muddying the waters of the information on this board with posts like this. Cheers, Brent Calkin Quote Link to comment Share on other sites More sharing options...
Herbert Verdino Posted January 19, 2014 Author Report Share Posted January 19, 2014 Thank you, Larry! What a great support! Makes me even more Lectro fan :-). And thank you all for your thoughts on my question. Maybe this flat sound Senator mentioned was produced by a cheap phantom power supply? Maybe the signal was influenced by running threw the circuit of the phantom power supply... Anyway. I will spend my money now in some more SM transmitters and use them for my boom as well. ;-) All the best. Quote Link to comment Share on other sites More sharing options...
John Blankenship Posted January 19, 2014 Report Share Posted January 19, 2014 Thank you, Larry! What a great support! Makes me even more Lectro fan :-). And thank you all for your thoughts on my question. Maybe this flat sound Senator mentioned was produced by a cheap phantom power supply? Maybe the signal was influenced by running threw the circuit of the phantom power supply... Anyway. I will spend my money now in some more SM transmitters and use them for my boom as well. ;-) All the best. Senator Mike was trying to make a joke based on the shape of the transmitters, not on their sound. You can ignore what he said in this thread and be happier for it. Quote Link to comment Share on other sites More sharing options...
JWL Posted January 19, 2014 Report Share Posted January 19, 2014 Thanks Larry for your contribution. Senator Tourettes, I can deal with your constant need for attention with posts that say nothing but fill space, but please try to refrain from spreading misinformation. I assume your Flat and Full bodied comment was based on some private hilarious joke regarding the shape of the different transmitters. But really you are just seriously muddying the waters of the information on this board with posts like this. Cheers, Brent Calkin +1 Quote Link to comment Share on other sites More sharing options...
Christian Spaeth Posted January 19, 2014 Report Share Posted January 19, 2014 As a teacher you should know sarcasm is not appropriate for discussing professional issues, Mike. Not cool. Quote Link to comment Share on other sites More sharing options...
