Sebastian Posted January 19, 2014 Report Share Posted January 19, 2014 Hi guys Just needing a little assistance regarding the cable techniques Rx emergency unit which I recently bought. I'm finding the noise floor extremely high and I'm sure that shouldn't be the case. I'm using a Lectro 411a, outputting line level @ 0dBu from the receiver into the mix in of my 302. I'm getting decent audio levels but the hiss is bad. I've tried it on my other 411a with the same results. The one possible cause I thought of could be the balanced cable which I wired myself, however from an XLR to TA3F the wiring is straight forward 1 to 1, 2 to 2 and 3 to 3. Unless I need to add a resistor somewhere. Any help would be appreciated! Sebastian Quote Link to comment Share on other sites More sharing options...
rich Posted January 19, 2014 Report Share Posted January 19, 2014 i am guessing you are using the mix in input of of your 302. it is wired 1 ground, 2 left, 3 right. and the shell of the connector must be connected to pin 1. you could also try using the return input with the appropriate setting in the menu. Quote Link to comment Share on other sites More sharing options...
Sebastian Posted January 19, 2014 Author Report Share Posted January 19, 2014 Thanks Richard, Problem's solved. The TA3F pin 1 wasn't connected to the connector shell on the 302 side. Happy days! Quote Link to comment Share on other sites More sharing options...
