Prahlad Strickland Posted February 12, 2014 Report Share Posted February 12, 2014 Just wondering the Order of attack with such a thin wire?, shrink wrap down to thicken it up? What about where the cable exits the lemo connector, I see the Trew audio cables etc when they do Lemo's it has that black "BOOT" I'm guessing that is a special type of shrink wrap?, trying to get some to add strain relief like they do... Any idea where to get this? Anyone have a countryman B6 wired for Lectro and willing to post a picture of how it's strain relieved / shrink wrapped (booted) ?? Thanks heaps for any help Quote Link to comment Share on other sites More sharing options...
John Blankenship Posted February 12, 2014 Report Share Posted February 12, 2014 Are you using the push-on or screw-on Lemo? The black boot is a standard Lemo item for both. Depending upon how the B6 wire fits inside the Lemo components, I would add a layer or two of heat shrink tubing to build the diameter and add strength and strain relief to the cable. Quote Link to comment Share on other sites More sharing options...
efksound Posted February 12, 2014 Report Share Posted February 12, 2014 I was thinking of doing some TAF5 to Lemo cable adaptors to be able to use my B6 with both systems (Lectro and Zax). Anyone done this ? Quote Link to comment Share on other sites More sharing options...
John Blankenship Posted February 12, 2014 Report Share Posted February 12, 2014 I was thinking of doing some TAF5 to Lemo cable adaptors to be able to use my B6 with both systems (Lectro and Zax). Anyone done this ? Yes. Quote Link to comment Share on other sites More sharing options...
studiomprd Posted February 12, 2014 Report Share Posted February 12, 2014 me too... laddie: " Just wondering the Order of attack " remove old connector first! yes, of course shrink tubing helps, and there are any number of ways to accomplish this wiring, but the tiny cables involved require care and experience. Quote Link to comment Share on other sites More sharing options...
greg sextro Posted February 12, 2014 Report Share Posted February 12, 2014 How old is the b6? Might be best to just buy new Quote Link to comment Share on other sites More sharing options...
Prahlad Strickland Posted February 13, 2014 Author Report Share Posted February 13, 2014 Are you using the push-on or screw-on Lemo? The black boot is a standard Lemo item for both. Depending upon how the B6 wire fits inside the Lemo components, I would add a layer or two of heat shrink tubing to build the diameter and add strength and strain relief to the cable. Mine didn't ship with Boots :-( from trew audio Pushons is what i ordered Quote Link to comment Share on other sites More sharing options...
Prahlad Strickland Posted February 13, 2014 Author Report Share Posted February 13, 2014 me too... laddie: " Just wondering the Order of attack " remove old connector first! yes, of course shrink tubing helps, and there are any number of ways to accomplish this wiring, but the tiny cables involved require care and experience. I'll be thinking of u as i wire it up i'll do the shrink wrap and try get a boot... do they supposed to come with boots? Quote Link to comment Share on other sites More sharing options...
John Blankenship Posted February 13, 2014 Report Share Posted February 13, 2014 Mine didn't ship with Boots :-( from trew audio Pushons is what i ordered It really depends on who you're buying them from and how you specify what you're getting. It's worth checking whenever you buy them. I've encountered them packaged with, and without, boots, and also a la carte for each of the pieces that make up a complete assembly. BTW: It's not "shrink wrap" you'd typically use, it's "heat shrink tubing." Not trying to be picky -- just to help you get the right thing. Have you ever wired Lemos before -- or perhaps something else that precision? They can be pretty tricky, even for someone experienced with soldering. For Zaxcom transmitters be sure to connect the ground to the Lemo's shell. Quote Link to comment Share on other sites More sharing options...
Prahlad Strickland Posted February 15, 2014 Author Report Share Posted February 15, 2014 It really depends on who you're buying them from and how you specify what you're getting. It's worth checking whenever you buy them. I've encountered them packaged with, and without, boots, and also a la carte for each of the pieces that make up a complete assembly. BTW: It's not "shrink wrap" you'd typically use, it's "heat shrink tubing." Not trying to be picky -- just to help you get the right thing. Have you ever wired Lemos before -- or perhaps something else that precision? They can be pretty tricky, even for someone experienced with soldering. For Zaxcom transmitters be sure to connect the ground to the Lemo's shell. Good to know, I actually didn't even know it was a Lemo product ( the tubing) I've wired TC cables for Red One cameras, at the time of doing it, I wish I wasn't doing it, haha Quote Link to comment Share on other sites More sharing options...
John Blankenship Posted February 15, 2014 Report Share Posted February 15, 2014 Good to know, I actually didn't even know it was a Lemo product ( the tubing) ... I get the impression we're in two different conversations together. I was referring to the boots as being a Lemo product that can either come with an assembly, or specified separately. Quote Link to comment Share on other sites More sharing options...
Prahlad Strickland Posted February 15, 2014 Author Report Share Posted February 15, 2014 I get the impression we're in two different conversations together. I was referring to the boots as being a Lemo product that can either come with an assembly, or specified separately. Yeh I got that, What I meant was taht I thought it was just a classy shiny shrink wrap. I'll specify them to be added to the order next time. Quote Link to comment Share on other sites More sharing options...
Prahlad Strickland Posted February 15, 2014 Author Report Share Posted February 15, 2014 For Zaxcom transmitters be sure to connect the ground to the Lemo's shell. So I'm taking that the ground is connected to pin 1 + shell... ? Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted February 15, 2014 Report Share Posted February 15, 2014 shell to ground - correct Quote Link to comment Share on other sites More sharing options...
fatfatjames Posted February 17, 2014 Report Share Posted February 17, 2014 how to ground to the shell for lemo? Quote Link to comment Share on other sites More sharing options...
vale Posted March 1, 2014 Report Share Posted March 1, 2014 I'm in the same situation. Just received my Lemo connectors (FGB.00.303.CLAD22) without the boots... Ordered directly from LEMO. Maybe I was not so clever, because somewhere there was written that the boots were supposed to be ordered separately. Now, while I'll be waiting to receive these boots, could I try to wire and use my connectors without them? Anyone here tried to do something similar? Could the connector (or the connections) be stressed or damaged this way? ps. I've just seen in an other topic () that Soundlikejustin was mentioning Lemo part GMF.00.018.DI for boots. So I'm going to order them (even if I can't able to find them with the last letter 'I' on the Lemo website, but it is supposed to be the color). Thanks, vale. Mine didn't ship with Boots :-( from trew audio Pushons is what i ordered Quote Link to comment Share on other sites More sharing options...
hobbiesodd Posted July 19, 2020 Report Share Posted July 19, 2020 Once again, this forum proves to be a wealth of useful information & pro tips. Thanks to this thread (and a couple of others on here) I was able to successfully rewire a bunch of lavs for Zax with significantly less turmoil than I would’ve endured had the people before me not shared their experiences. Special shout-out to @John Blankenship for discovering the best Lemo connector option as well as sharing the perfect ground-to-shell technique. After 20+ years in this industry I am still learning new things, and thanks to everyone here it’s a lot easier than it used to be. Cheers, Evan Meszaros Quote Link to comment Share on other sites More sharing options...
