Ron Scelza Posted April 18, 2006 Report Share Posted April 18, 2006 Hi Take, I have been playing with Boom Recorder this Show and Love it.. I haven't been able to get the time code to start the recording. Using a Deva V in record roll and Traveller..... Thanks in advance Sincerely Ron Scelza CAS Quote Link to comment Share on other sites More sharing options...
Philip Perkins Posted April 18, 2006 Report Share Posted April 18, 2006 If BR doesn't presently do this it would definitely be a great thing to add, esp for those using BR as a backup recorder. I don't think Metacorder can do this and I wish it could. Philip Perkins Quote Link to comment Share on other sites More sharing options...
takev Posted April 18, 2006 Report Share Posted April 18, 2006 Hello Philip, The autostart button on the right of the transport buttons will start and stop Boom Recorder, depending on the availability of the timecode. However currently this only works when the complete timecode signal turns on and off, not when the timecode is stuck against a single time. I can fix this, but not right now. Cheers, Take Quote Link to comment Share on other sites More sharing options...
Jeff Wexler Posted April 18, 2006 Report Share Posted April 18, 2006 Hello Philip, The autostart button on the right of the transport buttons will start and stop Boom Recorder, depending on the availability of the timecode. However currently this only works when the complete timecode signal turns on and off, not when the timecode is stuck against a single time. I can fix this, but not right now. Cheers,  Take That would be a good feature and it is good to know that you could implement it the way you describe (but I know, not now). It would then work in those situations where you may be working with cameras in rec run and BoomRecorder would autostart (go into record) based on having seen running code from the camera. - JW Quote Link to comment Share on other sites More sharing options...
takev Posted April 18, 2006 Report Share Posted April 18, 2006 That would be a good feature and it is good to know that you could implement it the way you describe (but I know, not now). It would then work in those situations where you may be working with cameras in rec run and BoomRecorder would autostart (go into record) based on having seen running code from the camera. Hello Jeff, Did you know there is also an other timecode trick in Boom Recorder? Where Boom Recorder will automatically start a new file on a timecode break. This is useful when you want to copy a TC-DAT hands off. You can turn on this feature in the preferences panel. I guess both features will at be joined together when I fix the autostart. Cheers, Take Quote Link to comment Share on other sites More sharing options...
Philip Perkins Posted April 18, 2006 Report Share Posted April 18, 2006 Cool as well, but if you could make the program start and stop recording in new files/takes when TC starts and stops it would REALLY be a great thing. Video TC never "goes away" in stop mode in most set ups, it just stops counting and sends out the same number over and over. (I've had a time trying to explain this to Tascam as well.) Philip Perkins Quote Link to comment Share on other sites More sharing options...
takev Posted October 17, 2006 Report Share Posted October 17, 2006 Hello everyone, This should now function correctly in 7.14 (or 7.14.1) Cheers, Take Quote Link to comment Share on other sites More sharing options...
