Reference tone for film
redge
In the US broadcast industry, all the post people will assume your tone is at -20, and that it will read @ that level and have audio peaks in the appropriate relationship to that level (up into the -10 range).  They will also assume that they don't have to take their level controls out of preset or default mode to accomodate your levels, and will whine if they do have to.
Philip Perkins
Dear R.Edge,
If you're going direct into your 702T's mic preamps with your Schoeps rig, don't worry about reference tones. These references are only pertinent if you are connecting to an external mixer or other device, and for playback, as Oleg pointed out. You can record your signals as hot as you need, as long as you're not over 0dbfsc. As mentioned by earlier posters, normal dialogue peaks should hit between -12 and -8 comfortably. For ambiences, salt and season to your own taste. The 702T's preamps shouldn't add appreciable noise if you have to crank things up for nature sounds etc. Good luck on your trip.
Chris Newton
